◆ RecorderPeriodSet()
void RecorderPeriodSet ( uint32_t samples)
RecorderPeriodSet sets the number of samples between records.
samplesNumber of samples between records, 0 to 32767.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5870
Definition rsi.h:11559
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3846
Definition rsienums.h:434
RecordPerformance.cpp, and Recorder.cs.
