using RSI.RapidCode.dotNET;
using NUnit.Framework;
using System;
#if DOXYGEN
#endif
[Test]
public void Recorder()
const int VALUES_PER_RECORD = 2;
const int RECORD_PERIOD_SAMPLES = 1;
const int RECORD_TIME = 250;
const int INPUT_INDEX = 0;
Axis axis = CreateAndReadyAxis(Constants.AXIS_NUMBER);
Console.WriteLine("There are {0} Records available.", recordsAvailable);
i = recordsAvailable;
Get the number of records that are stored and ready for reading.
void RecorderStart()
Start recording data.
Configure recorder as circular buffer (or not).
Retrieve one record of recorded data.
Set the number of data values to be recorded.
Get one value from a retrieved record.
void RecorderStop()
Stop recording data.
void RecorderReset()
Reset the recorder.
Setup the addresses to be recorded.
Set the number of samples between records.
bool RecorderEnabledGet()
Determine if the recorder is recording.
RapidCodeOS * OS
