◆ RecorderDataCountSet()
void RecorderDataCountSet ( int32_t count)
RecorderDataCountSet sets the number of data values to be recorded.
countThe number of values to be recorded.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5526
Definition rsi.h:10941
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3673
Definition rsienums.h:404
Definition rsienums.h:433
RecordPerformance.cpp, and Recorder.cs.
