11.0.3
AmpFaultTriggerStateGet()
bool AmpFaultTriggerStateGet
AmpFaultTriggerStateGet returns the trigger state.
(int32_t) 1 = triggers on active high signal, 0 = triggers on active low signal.
Axis: Configuration
// set
axis.
AmpEnableSet
false
// disable the amp
axis.
AmpFaultActionSet
.RSIActionABORT);
// set the action that will occur when there is an amp fault.
axis.
AmpFaultTriggerStateSet
false
// set the state of the amp fault.
axis.
AmpFaultDurationSet
(1);
// set the duration (seconds) required before the Amp Fault event triggers.
// get
bool
isEnabled = axis.
AmpEnableGet
faultAction = axis.
AmpFaultActionGet
bool
faultTriggerState = axis.
double
faultDuration = axis.
AmpFaultDurationGet
Go to axis screen->Limits & Actions. In the image below, AmpFaultTriggerStateGet returns the trigger state shown in the Amp Fault box. It currently triggers on a HIGH because the "High" checkbox is checked.
axis-config-ampfault.cs
, and
axis-configuration.cpp
1.15.0
