10.6.0
AmpFaultDurationGet()
double AmpFaultDurationGet
AmpFaultDurationGet returns the duration required before the Amp Fault event triggers.
(double) Seconds.
Axis: Configuration
const
double
AMP_FAULT_DURATION_TIME = 1;
//value in seconds
// SET
axis.
AmpEnableSet
false
// Disable the amp
axis.
AmpFaultActionSet
.RSIActionABORT);
// Set the action that will occur when there is an amp fault.
axis.
AmpFaultTriggerStateSet
false
//Set the state of the amp fault.
axis.
AmpFaultDurationSet
(AMP_FAULT_DURATION_TIME);
//Set the duration required before the Amp Fault event triggers.
// GET
var isEnabled = axis.
AmpEnableGet
var faultAction = axis.
AmpFaultActionGet
var faultTriggerState = axis.
AmpFaultTriggerStateGet
var faultDuration = axis.
AmpFaultDurationGet
Go to axis screen->Limits & Actions. In the image below, AmpFaultDurationGet returns the value in the "Duration" box in the Amp Fault box. It is currently 0.
AmpFaultDurationSet
AxisConfig.cs
, and
AxisConfiguration.cpp
1.10.0
