10.7.1
AmpFaultActionGet()
AmpFaultActionGet
AmpFaultActionGet returns the action which will occur when an Amp Fault is triggered.
) Action taken on Amp Fault event.
Note:
Available Actions are
Abort()
EStop()
Stop()
, None,
EStopAbort()
, and
EStopModify()
Axis: Configuration
// set
axis.
AmpEnableSet
false
// disable the amp
axis.
AmpFaultActionSet
.RSIActionABORT);
// set the action that will occur when there is an amp fault.
axis.
AmpFaultTriggerStateSet
false
// set the state of the amp fault.
axis.
AmpFaultDurationSet
(1);
// set the duration (seconds) required before the Amp Fault event triggers.
// get
bool
isEnabled = axis.
AmpEnableGet
faultAction = axis.
AmpFaultActionGet
bool
faultTriggerState = axis.
AmpFaultTriggerStateGet
double
faultDuration = axis.
AmpFaultDurationGet
Go to axis screen->Limits & Actions. In image below, AmpFaultActionGet returns the action type shown in the Amp Fault box. It is currently set to ABORT.
AmpFaultActionSet
AxisConfiguration.cpp
, and
axis-config-ampfault.cs
1.10.0
