Recorder.cs
25using RSI.RapidCode.dotNET; // Import our RapidCode Library.
26using NUnit.Framework;
27using System;
28
29#if DOXYGEN // RSI internal documentation use only
30using RSI.RapidCode;
31#endif
32
34class Recorder_Sample : StaticMemoryTestBase
35
36 {
37 [Test]
38 public void Recorder()
39 {
41 const int VALUES_PER_RECORD = 2; // How many values to store in each record.
42 const int RECORD_PERIOD_SAMPLES = 1; // How often to record data. (samples between consecutive records)
43 const int RECORD_TIME = 250; // How long to record. (in milliseconds)
44 const int INPUT_INDEX = 0;
45
46 // Get the host controller addresses for the values we want to record
47 // Number of processed Recorders in the controller.
48 controller.RecorderCountSet(1);
49
50 controller.AxisCountSet(1);
51 Axis axis = CreateAndReadyAxis(Constants.AXIS_NUMBER); // Helper function to setup an axis
52
53 UInt64 userBufferAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0); // Grabing an memory address to store a simulated IO point.
54 // Instead of using physical IO we will use simulated IO using a memory address as simulated IO. See the IO sample apps to see how to use a physical IO instead.
55 IOPoint input = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX); // Create a simulated IOpoint using userBuffer memory.
56
57 if (controller.RecorderEnabledGet() == true) // Check if the recorder is running already. If it is, stop it.
58 {
59 controller.RecorderStop(); // Stop recording.
60 controller.RecorderReset(); // Reset controller.
61 }
62
63 controller.RecorderPeriodSet(RECORD_PERIOD_SAMPLES); // Configure recorder to record every 'n' samples (Every 'n' ms)
64 controller.RecorderCircularBufferSet(false); // Do not use a circular buffer
65 controller.RecorderDataCountSet(VALUES_PER_RECORD); // Configure the number of values for each record. (how many things to record)
66 controller.RecorderDataAddressSet(0, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeACTUAL_POSITION)); // Configure the recoder to record values from this address (1st recorded address)
67 controller.RecorderDataAddressSet(1, input.AddressGet()); // Configure the recoder to record values from this address (2nd recorded address)
68
69 controller.RecorderStart(); // Start recording.
70 controller.OS.Sleep(RECORD_TIME); // Put this thread to sleep for some milliseconds.
71
72 int recordsAvailable = controller.RecorderRecordCountGet(); // find out how many records were recorded. (Get the number of records that are stored and ready for reading)
73
74 Console.WriteLine("There are {0} Records available.", recordsAvailable); // Print the number of records recorded.
75
76 for (int i = 0; i < recordsAvailable; i++) // Check every record recorded.
77 {
78 controller.RecorderRecordDataRetrieve(); // Retrieve one record of recorded data.
79
80 double positionRecord = controller.RecorderRecordDataDoubleGet(0); // Get the value from the 1st specified address. /use double
81 var digitalInputsValue = controller.RecorderRecordDataValueGet(1); // Get the value from the 2nd specified address.
82
83 if ((digitalInputsValue & input.MaskGet()) == input.MaskGet()) // We are checking to see if the digital input 1 bit changes. If it does then we record the position when that input went high.
84 {
85 i = recordsAvailable; // break from loop.
86 Console.WriteLine("Your encoder position was: " + positionRecord + " when the input triggered.");
87 }
88 }
89
90 controller.RecorderStop(); // Stop recording.
91 controller.RecorderReset(); // Reset controller.
93 }
94 }
Definition rsi.h:5870
Definition rsi.h:11559
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3846
Definition rsienums.h:434
