RecordPerformance.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: .
#include <iomanip>
// Helper function to calculate the minimum, maximum, and average of a vector of integers
static std::vector<int> MinMaxAvg(std::vector<int> data)
int min = data[0];
int max = data[0];
int sum = 0;
for (int i = 0; i < data.size(); i++)
if (data[i] < min)
min = data[i];
if (data[i] > max)
max = data[i];
sum += data[i];
int avg = sum / data.size();
return {min, max, avg};
int main()
const std::string SAMPLE_APP_NAME = "Utilities: Record Performance";
/* CONSTANTS */
const int RECORD_PERIOD_SAMPLES = 1; // Number of samples between each record.
const int RECORD_TIME = 1000; // Time in milliseconds to record for.
// Create the controller
MotionController *controller = MotionController::Create(&params);
/* SAMPLE APP BODY */
// Check if the network is started
int valuesPerRecord;
bool networkTimingEnabled = false;
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL)
std::cout << "Network is not operational. Only Firmware Timing Deltas will be recorded." << std::endl;
valuesPerRecord = 1;
// Enable network timing
controller->NetworkTimingEnableSet(true);
networkTimingEnabled = true;
valuesPerRecord = 3;
// Add a recorder
int recorderIndex = controller->RecorderCountGet();
controller->RecorderCountSet(recorderIndex + 1);
// Check if the recorder is running already, if it is then stop it
if (controller->RecorderEnabledGet(recorderIndex))
controller->RecorderStop(recorderIndex);
controller->RecorderReset(recorderIndex);
// Configure the recorder
controller->RecorderPeriodSet(RECORD_PERIOD_SAMPLES);
controller->RecorderCircularBufferSet(false);
controller->RecorderDataCountSet(valuesPerRecord);
controller->RecorderDataAddressSet(0, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeFIRMWARE_TIMING_DELTA));
if (networkTimingEnabled)
controller->RecorderDataAddressSet(1, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeNETWORK_TIMING_DELTA));
controller->RecorderDataAddressSet(2, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeNETWORK_TIMING_RECEIVE_DELTA));
// Start the recorder
controller->RecorderStart(recorderIndex);
controller->OS->Sleep(RECORD_TIME);
int recordCount = controller->RecorderRecordCountGet(recorderIndex);
std::cout << "There are " << recordCount << " records available." << std::endl;
// Read the records
std::vector<int> firmawareTimingDeltas(recordCount);
std::vector<int> networkTimingDeltas(recordCount);
std::vector<int> networkTimingReceiveDeltas(recordCount);
for (int i = 0; i < recordCount; i++)
controller->RecorderRecordDataRetrieve(recorderIndex);
firmawareTimingDeltas[i] = controller->RecorderRecordDataValueGet(recorderIndex, 0);
networkTimingDeltas[i] = controller->RecorderRecordDataValueGet(recorderIndex, 1);
networkTimingReceiveDeltas[i] = controller->RecorderRecordDataValueGet(recorderIndex, 2);
// Calculate the statistics
std::vector<int> firmwareTimingStats = MinMaxAvg(firmawareTimingDeltas);
std::cout << "Firmware Timing Deltas (us): ";
std::cout << " Min = " << std::setw(4) << firmwareTimingStats[0];
std::cout << " Max = " << std::setw(4) << firmwareTimingStats[1];
std::cout << " Avg = " << std::setw(4) << firmwareTimingStats[2] << std::endl;
std::vector<int> networkTimingStats = MinMaxAvg(networkTimingDeltas);
std::cout << "Network Timing Deltas (us): ";
std::cout << " Min = " << std::setw(4) << networkTimingStats[0];
std::cout << " Max = " << std::setw(4) << networkTimingStats[1];
std::cout << " Avg = " << std::setw(4) << networkTimingStats[2] << std::endl;
std::vector<int> networkTimingReceiveStats = MinMaxAvg(networkTimingReceiveDeltas);
std::cout << "Network Timing Receive Deltas (us):";
std::cout << " Min = " << std::setw(4) << networkTimingReceiveStats[0];
std::cout << " Max = " << std::setw(4) << networkTimingReceiveStats[1];
std::cout << " Avg = " << std::setw(4) << networkTimingReceiveStats[2] << std::endl;
// Delete the recorder
controller->RecorderCountSet(recorderIndex);
exitCode = 0; // Set the exit code to success.
exitCode = -1;
controller->Delete();
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
int32_t RecorderCountGet()
Get the number of Recorder available in the firmware.
bool RecorderEnabledGet()
Definition rsi.h:800
RapidCodeOS * OS
Definition rsi.h:3846
void NetworkTimingEnableSet(bool enable)
Enable or disable the firmware to start timing the network packets.
Definition rsi.h:866
