HardwareLimits.cpp
23
24#include "rsi.h" // Import our RapidCode Library.
25#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
26#include "SampleApps.h"
27
28using namespace RSI::RapidCode; // Import the RapidCode namespace
29
31int HardwareLimits::Run()
32{
33 /* CONSTANTS */
34 // *NOTICE* The following constants must be configured before attempting to run with hardware.
35
36 // Axis configuration parameters
37 const int AXIS_COUNT = 1; // Specify how many axes we will be using in this sample.
38 const int AXIS_NUMBER = 0; // Specify which axis/motor we will be controlling.
39
40 const double USER_UNITS = 1048576; // Specify your counts per unit / user units. (the motor used in this example has 1048576 encoder pulses per revolution)
41
42 // Hardware Limit configuration parameters
43 const bool ACTIVE_HIGH = true; // Constant for active high.
44 const bool ACTIVE_LOW = false; // Constant for active low.
45 const double HW_POS_DURATION_TIME = 0.01; // Positive limit duration. (in seconds)
46 const double HW_NEG_DURATION_TIME = 0.01; // Negative limit duration. (in seconds)
47
48 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
49 USE_HARDWARE = false;
50
51 // The rmpPath only needs to be set if the project directory is different than the rapid setup directory.
52 // *NOTICE* When setting the rmpPath, be sure to uncomment the rmpPath arguement in MotionController::CreateFromSoftware() in the Run() function.
53 const std::string rmpPath = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)
54
55 /* SAMPLE APP BODY */
56
57 // Initialize MotionController class.
58 MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
59 SampleAppsHelper::CheckErrors(controller); // [Helper Function] Check that the axis has been initialize correctly.
60
61 // Setup the controller for the appropriate hardware configuration.
62 if (USE_HARDWARE)
63 {
65 }
66 else
67 {
68 SampleAppsHelper::SetupControllerForPhantoms(controller, AXIS_COUNT, { AXIS_NUMBER });
69 }
70
71 try
72 {
73 Axis* axis = controller->AxisGet(AXIS_NUMBER); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
74 SampleAppsHelper::CheckErrors(axis); // [Helper Function] Check that the axis has been initialize correctly.
75
76 printf("Hardware Limits Example\n");
77
78 // Change Hardware POSITIVE (+) Limit characteristicpp.
79 axis->HardwarePosLimitActionSet(RSIAction::RSIActionE_STOP); // Set the positive limit action to E_STOP.
80 printf("\nHardware Positive Limit Action set to %i", axis->HardwarePosLimitActionGet());
81
82 axis->HardwarePosLimitTriggerStateSet(ACTIVE_HIGH); // Set the positive limit trigger state to ACTIVE_HIGH.
83 printf("\nHardware Positive Limit TriggerState set to %i", axis->HardwarePosLimitTriggerStateGet());
84
85 axis->HardwarePosLimitDurationSet(HW_POS_DURATION_TIME); // Set the positive limit duration to 0.01 seconds.
86 printf("\nHardware Positive Limit Duration set to %f seconds", axis->HardwarePosLimitDurationGet());
87
88 // Change Hardware NEGATIVE (-) Limit charateristicpp.
89 axis->HardwareNegLimitActionSet(RSIAction::RSIActionE_STOP); // Set the negative limit action to E_STOP.
90 printf("\nHardware Negative Limit Action set to %i", axis->HardwareNegLimitActionGet());
91
92 axis->HardwareNegLimitTriggerStateSet(ACTIVE_LOW); // Set the negative limit trigger state to ACTIVE_LOW.
93 printf("\nHardware Negative Limit TriggerState set to %i", axis->HardwareNegLimitTriggerStateGet());
94
95 axis->HardwareNegLimitDurationSet(HW_NEG_DURATION_TIME); // Set the negative limit duration to 0.01 seconds.
96 printf("\nHardware Negative Limit Duration set to %f seconds", axis->HardwareNegLimitDurationGet());
97
98 printf("\nAll Hardware Limit characteristicpp set\n");
99 }
100 catch (RsiError const& err)
101 {
102 printf("\n%s\n", err.text);
103 return -1;
104 }
105 controller->Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
106 return 0;
107}
sets the trigger state.
trigger state return.
Trigger state return.
Sets the trigger state.
@ RSIActionE_STOP
Definition rsienums.h:1167
