🧩 Template
Basic template for getting started with RapidCode.
In this page:
📜 Basic Template
This template demonstrates basic Controller and Axis initialization, configuration, and how to enable an axis and prepare it for motion. Use this as a starting point for RapidCode applications.
/* This is a basic template you can use to get up and running quickly with RapidCode.
It demonstrates simple controller and axis initialization, basic axis configuration,
Console.WriteLine("📜 Basic Template");
// create rmp controller
var createParams = new MotionController.CreationParameters();
#if WINDOWS
createParams.RmpPath = Constants.RMP_WINDOWS_PATH; // default is "C:\RSI\X.X.X"
createParams.NodeName = Constants.RMP_NODE_NAME; // default is "NodeA"
#elif LINUX
createParams.RmpPath = Constants.RMP_LINUX_PATH; // default is root folder "/rsi/"
createParams.NicPrimary = Constants.RMP_NIC_PRIMARY; // default is empty since we do not have a network by default
createParams.CpuAffinity = Constants.RMP_CPU_AFFINITY; // default is 0 since this is what our tests use
#endif
MotionController controller = MotionController.Create(createParams);
Helpers.CheckErrors(controller); // ALWAYS check for errors after creating a RapidCode object
// start the ethercat network
//Helpers.NetworkStart(controller); // uncomment if using real (not phantom) axis. samples use phantoms by default
// get your axis
Helpers.CheckErrors(axis); // ALWAYS check for errors after creating a RapidCode object
// specify the counts per unit/user units
double userUnits = Constants.AXIS_0_USER_UNITS;
axis.UserUnitsSet(userUnits); // they are often used to change counts to distance (cm, inch, etc), degree, full rotation, etc.
// configure axis limits and error handling
axis.ErrorLimitTriggerValueSet(1); // set position error limit trigger
axis.PositionSet(0); // make sure motor starts at position 0
axis.Abort(); // abort any motion
axis.ClearFaults(); // clear faults, resets to IDLE state
axis.AmpEnableSet(true, Constants.AMP_ENABLE_MS); // enable the motor
Console.WriteLine("Axis initialized and ready");
Console.WriteLine($"User Units: {userUnits}");
Console.WriteLine($"Current Position: {axis.CommandPositionGet()}");
Console.WriteLine($"Amp Enabled: {axis.AmpEnableGet()}");
//-----INSERT YOUR CODE HERE-----
axis.AmpEnableSet(false); // disable the motor
controller.Delete(); // delete the controller as the program exits to ensure memory is deallocated in the correct order
Definition _constants.cs:26
const int RMP_CPU_AFFINITY
Definition _constants.cs:9
const string RMP_LINUX_PATH
Default: /rsi.
const string RMP_NIC_PRIMARY
Default: "".
Definition _constants.cs:8
const string RMP_NODE_NAME
Default: NodeA.
Definition _constants.cs:7
const string RMP_WINDOWS_PATH
Default: .....
Definition _constants.cs:5
Definition rsi.h:5963
Definition rsi.h:862
