Monitoring: Recorder
Learn how to use Recorders in C#.
In this page:
📜 Recorder
Learn how to use the Recorder 📖 to track multiple controller parameters over time. Shows how to configure the recorder, record axis position and digital input values, and retrieve recorded data to find when specific events occurred.
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:12981
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
