Learn how to work with Path motion in C#.
- Warning
In this page:
📜 Motion: Path
Learn how to set up and run Path Motion 📖 with a Robot object. Shows how to create kinematic models, program path movements using lines and arcs, and execute coordinated multi-axis motion.
using System.Threading;
Console.WriteLine("📜 Motion: Path");
Axis xAxis = controller.
AxisGet(Constants.AXIS_0_INDEX);
Axis yAxis = controller.
AxisGet(Constants.AXIS_1_INDEX);
Axis zAxis = controller.
AxisGet(Constants.AXIS_2_INDEX);
Axis aAxis = controller.
AxisGet(Constants.AXIS_3_INDEX);
Axis bAxis = controller.
AxisGet(Constants.AXIS_4_INDEX);
Axis cAxis = controller.
AxisGet(Constants.AXIS_5_INDEX);
Axis[] axes = [ xAxis, yAxis, zAxis, aAxis, bAxis, cAxis ];
jointsMultiAxis.
AxesAdd(axes, axes.Length);
const LinearUnits units = LinearUnits.Meters;
const string modelName = "RSI_XYZABC_Meters";
const double scaling = 1.0;
const double offset = 0.0;
builder.UnitsSet(units);
builder.JointAdd(
new LinearJointMapping(2,
CartesianAxis.Z) { ExpectedLabel = zLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(
new LinearJointMapping(3,
CartesianAxis.Roll) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(
new LinearJointMapping(4,
CartesianAxis.Pitch) { ExpectedLabel = bLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(
new LinearJointMapping(5,
CartesianAxis.Yaw) { ExpectedLabel = cLabel, Scaling = scaling, Offset = offset });
Console.WriteLine($"Robot model: {robot.ModelGet().NameGet()}");
Console.WriteLine($"Robot units: {robot.ModelGet().UnitsGet()}");
robot.PathAccelerationSet(1000);
robot.PathVelocitySet(50);
robot.PathProgrammingModeSet(
PathMode.Absolute);
robot.PathLine(target: new Pose(1, 1, 1));
robot.PathArc(
target: new Pose(0, 2, 1),
center: new Vector3d(0, 1, 1),
robot.Run();
while (robot.IsRunning())
Thread.Sleep(100);
Console.WriteLine("Path motion executing...");
static void ConfigurePhantomAxis(Axis phantomAxis)
Configures a phantom axis on the controller.
Helpers class provides static methods for common tasks in RMP applications.
PathMode
Motion types. For G-code use and Cartesian path motion.
CartesianAxis
RotationDirection
Rotational directions about an axis.
📜 Motion: Path Gantry
Learn how to set up a kinematic model with a gantry prime axis for Path Motion 📖 . Shows how to configure a 1:1 geared axis system where two physical axes work together.
Console.WriteLine("📜 Motion: Path Gantry");
const string yPrimeLabel = "Y-Prime";
Axis primeAxis = controller.
Axis[] axes = [xAxis, yAxis, primeAxis];
jointsMultiAxis.
const LinearUnits units = LinearUnits.Millimeters;
const string modelName = "RSI_XY_Yp";
builder.JointAdd(
CartesianAxis.Y) { ExpectedLabel = yPrimeLabel, Scaling = scaling, Offset = offset });
const int motionFrameBufferSize = 50;
Robot robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, motionFrameBufferSize);
Console.WriteLine($"Model name: {robot.ModelGet().NameGet()}");
Console.WriteLine($"Model units: {robot.ModelGet().UnitsGet()}");
Console.WriteLine("Gantry configuration: Y-axis and Y-Prime axis are geared 1:1");
📜 Motion: Path 3D Rendering
Learn how to get 3D path points for rendering visualization from Path Motion 📖 . Shows how to retrieve planned positions for use with 3D graphics libraries.
Console.WriteLine("📜 Motion: Path 3D Rendering");
Axis[] axes = [xAxis, yAxis, zAxis];
jointsMultiAxis.
const string modelName = "RSI_XYZ";
builder.UnitsSet(LinearUnits.Millimeters);
builder.JointAdd(
robot.PathAccelerationSet(100);
PathMode.Absolute);
robot.PathArc(
robot.PathProcessLoadedMoves();
Console.WriteLine("Retrieving 3D path points for rendering:");
const ulong frameCount = 500;
ulong startFrame = 0;
int totalPointCount = 0;
ulong retrievedFrames;
do
RapidVectorRobotPosition positions = robot.PathPlannedPositionsGet(startFrame, frameCount);
retrievedFrames = positions.Size();
foreach (RobotPosition position in positions.ToArray())
Vector3d spatial = position.Pose.Position;
if (totalPointCount < 4)
Console.WriteLine($"Point {totalPointCount}: X={spatial.X:F2}, Y={spatial.Y:F2}, Z={spatial.Z:F2}");
totalPointCount++;
startFrame += retrievedFrames;
while (retrievedFrames == frameCount);
Console.WriteLine($"Total 3D points retrieved: {totalPointCount}");
