Motion: G-Code
Learn how to work with G-Code motion in C#.
In this page:
πŸ“œ Motion: G-Code
Learn how to set up and run G-Code 📖 motion with a Robot object. Shows how to create kinematic models, load G-Code programs, register callbacks for M-codes, and monitor execution progress during motion.
/* This sample demonstrates how to set up and run G-Code motion with a Robot object.
Shows how to create a kinematic model, load G-Code programs, and execute them.
Includes callback handling for M-codes and monitoring execution progress.
using System.Threading;
Console.WriteLine("πŸ“œ Motion: G-Code");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 4, minRequiredSampleMultiAxisCount: 1);
// sample G-Code program
string gcodeProgram = @"G91; Sets the programming mode to RELATIVE
G64; Turns off exact stop mode (Default)
G1 X1.0 Y0.0 Z0.0 A1.0 F60.0; Move on USERUNIT in positive x direction at 60in/min. Moves Free axis A to position 1.0.
G3 X1 Y1 I0 J1; Counter clockwise arc with a center point of 0,1,0 and end point of 1,1,0 relative to the current position
M80; Show how to use an M-code with GcodeCallback!";
// set robot axis labels
// get the 4 axis needed for XYZA robot
Helpers.CheckErrors(xAxis);
Helpers.CheckErrors(yAxis);
Axis zAxis = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(zAxis);
Axis aAxis = controller.AxisGet(Constants.AXIS_3_INDEX);
Helpers.CheckErrors(aAxis);
// configure phantom axes
Helpers.PhantomAxisReset(zAxis);
Helpers.PhantomAxisReset(aAxis);
// set axis labels
xAxis.UserLabelSet(xLabel);
yAxis.UserLabelSet(yLabel);
zAxis.UserLabelSet(zLabel);
aAxis.UserLabelSet(aLabel);
// create multi-axis object for joints
MultiAxis jointsMultiAxis = controller.MultiAxisGet(0);
Axis[] axes = [xAxis, yAxis, zAxis, aAxis];
jointsMultiAxis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
// create kinematic model
const double scaling = 1.0;
const double offset = 0.0;
builder.FreeAxisAdd(new ModelAxisMapping(3) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
// set free axis accel & decel before creating the robot object
// create Robot object
Robot robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
Helpers.CheckErrors(robot);
// set robot acceleration
robot.Gcode.AccelerationRateSet(1000);
// the free axis index refers to the index in the RobotPosition freeAxes array
robot.Gcode.FreeAxisLetterSet(gcodeLetter: 'A', freeAxisIndex: 0);
// register callback for M-code commands (note: callback class would need to be defined separately)
SampleGcodeCallback callback = new();
robot.Gcode.CallbackRegister(callback);
// load and prepare G-Code for execution
robot.Gcode.Load(gcodeProgram);
Console.WriteLine($"Error loading G-Code: {e.Message}");
Helpers.CheckErrors(robot.Gcode); // get additional G-Code error details
throw;
// print motion details
Console.WriteLine($"G-Code Line Count: {robot.Gcode.LineCountGet()}");
Console.WriteLine($"G-Code Error Log Count: {robot.Gcode.ErrorLogCountGet()}");
Console.WriteLine($"G-code estimated run time: {robot.Gcode.DurationGet()} seconds");
// start motion
robot.Gcode.Run();
// monitor execution
Int64 activeLineNumber = 0;
do
Thread.Sleep(200);
if (activeLineNumber != robot.Gcode.ExecutingLineNumberGet()) // only write if on new line
activeLineNumber = robot.Gcode.ExecutingLineNumberGet();
Console.WriteLine($"G-Code Line Number: {activeLineNumber}");
} while (robot.Gcode.IsRunning());
Helpers.CheckErrors(robot.Gcode); // check for motion errors
Console.WriteLine("βœ… G-Code motion completed successfully");
public class SampleGcodeCallback : GcodeCallback
public override void Execute(GcodeCallbackData data)
Console.WriteLine("G-Code Callback executed: " + data.LineNumber + " " + data.LineText);
// if you want to notify the Gcode object that there's an error processing, set its error details:
// data.UserError.number = RSIErrorMessage.RSI_ERROR_MESSAGE_DYNAMIC;
// data.UserError.text = "This is an error from the callback.";
const int AXIS_3_INDEX
Default: 3.
Definition _constants.cs:23
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
Definition rsi.h:5962
Definition rsi.h:850
Definition rsi.h:10883
πŸ“œ Motion: G-Code Units
Learn how changing linear units affects G-Code 📖 velocity and acceleration setters. Shows how to work with different unit systems and understand the impact on motion parameters.
/* This sample demonstrates how changing linear units affects G-Code velocity and acceleration setters.
Shows how to work with different unit systems in G-Code and understand the impact on motion parameters.
Console.WriteLine("πŸ“œ Motion: G-Code Units");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 6, minRequiredSampleMultiAxisCount: 1);
// get the 6 axis needed for XYZABC robot
Axis bAxis = controller.AxisGet(Constants.AXIS_4_INDEX);
Helpers.CheckErrors(bAxis);
Axis cAxis = controller.AxisGet(Constants.AXIS_5_INDEX);
Helpers.CheckErrors(cAxis);
Helpers.PhantomAxisReset(bAxis);
Helpers.PhantomAxisReset(cAxis);
// set axis labels
bAxis.UserLabelSet(bLabel);
cAxis.UserLabelSet(cLabel);
Axis[] axes = [xAxis, yAxis, zAxis, aAxis, bAxis, cAxis];
// create kinematic model with centimeters
const LinearUnits units = LinearUnits.Centimeters;
const string modelName = "RSI_XYZABC_Centimeters";
// build model
builder.UnitsSet(units);
builder.JointAdd(new LinearJointMapping(3, CartesianAxis.Roll) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(4, CartesianAxis.Pitch) { ExpectedLabel = bLabel, Scaling = scaling, Offset = offset });
builder.JointAdd(new LinearJointMapping(5, CartesianAxis.Yaw) { ExpectedLabel = cLabel, Scaling = scaling, Offset = offset });
// note: to use the above kinematic model you must have a gantry (linear 1:1 kinematics)
// and each linear axis must have its user units scaled to millimeters
// this will return none - a gcode unit hasn't been established so it will use path units
// if path units are not set it will use user units
Console.WriteLine($"Initial G-Code units: {robot.Gcode.UnitsGet()}");
robot.Gcode.AccelerationRateSet(10); // sets G-Code acceleration to 10 Centimeters per MINUTE squared
robot.Gcode.FeedRateSet(10); // sets G-Code velocity to 10 Centimeters per MINUTE
Console.WriteLine($"Acceleration rate (cm/minΒ²): {robot.Gcode.AccelerationRateGet()}");
Console.WriteLine($"Feed rate (cm/min): {robot.Gcode.FeedRateGet()}");
robot.Gcode.UnitsSet(LinearUnits.Inches); // this is the same as executing G-Code line G20
Console.WriteLine($"G-Code units after setting to inches: {robot.Gcode.UnitsGet()}");
robot.Gcode.AccelerationRateSet(10); // sets G-Code acceleration to 10 Inches per MINUTE squared
robot.Gcode.FeedRateSet(10); // sets G-Code velocity to 10 Inches per MINUTE
Console.WriteLine($"Acceleration rate (in/minΒ²): {robot.Gcode.AccelerationRateGet()}");
Console.WriteLine($"Feed rate (in/min): {robot.Gcode.FeedRateGet()}");
const int AXIS_5_INDEX
Default: 5.
Definition _constants.cs:25
const int AXIS_4_INDEX
Default: 4.
Definition _constants.cs:24
