gcode-loading
This method parses and processes the Gcode program. The program can be run by calling the Run() method.
Exceptions
RsiErrorIf exceptions are enabled and the program fails to parse or process, the first error encountered is thrown. The corresponding line number can be found via Gcode::SyntaxErrorLineNumberGet. Additional RsiError exceptions are logged on the Gcode object.
/* This sample demonstrates how to set up and run G-Code motion with a Robot object.
Shows how to create a kinematic model, load G-Code programs, and execute them.
Includes callback handling for M-codes and monitoring execution progress.
using System.Threading;
Console.WriteLine("📜 Motion: G-Code");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 4, minRequiredSampleMultiAxisCount: 1);
// sample G-Code program
string gcodeProgram = @"G91; Sets the programming mode to RELATIVE
G64; Turns off exact stop mode (Default)
G1 X1.0 Y0.0 Z0.0 A1.0 F60.0; Move on USERUNIT in positive x direction at 60in/min. Moves Free axis A to position 1.0.
G3 X1 Y1 I0 J1; Counter clockwise arc with a center point of 0,1,0 and end point of 1,1,0 relative to the current position
M80; Show how to use an M-code with GcodeCallback!";
// set robot axis labels
// get the 4 axis needed for XYZA robot
Helpers.CheckErrors(xAxis);
Helpers.CheckErrors(yAxis);
Axis zAxis = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(zAxis);
Axis aAxis = controller.AxisGet(Constants.AXIS_3_INDEX);
Helpers.CheckErrors(aAxis);
// configure phantom axes
Helpers.PhantomAxisReset(zAxis);
Helpers.PhantomAxisReset(aAxis);
// set axis labels
xAxis.UserLabelSet(xLabel);
yAxis.UserLabelSet(yLabel);
zAxis.UserLabelSet(zLabel);
aAxis.UserLabelSet(aLabel);
// create multi-axis object for joints
int multiAxisMotionSupervisorIndex = controller.AxisCountGet(); // MultiAxis supervisor indices begin after Axis supervisor indices
Axis[] axes = [xAxis, yAxis, zAxis, aAxis];
jointsMultiAxis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
// create kinematic model
const double scaling = 1.0;
const double offset = 0.0;
builder.FreeAxisAdd(new ModelAxisMapping(3) { ExpectedLabel = aLabel, Scaling = scaling, Offset = offset });
// set free axis accel & decel before creating the robot object
// create Robot object
Robot robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
Helpers.CheckErrors(robot);
// set robot acceleration
robot.Gcode.AccelerationRateSet(1000);
// the free axis index refers to the index in the RobotPosition freeAxes array
robot.Gcode.FreeAxisLetterSet(gcodeLetter: 'A', freeAxisIndex: 0);
// register callback for M-code commands (note: callback class would need to be defined separately)
// RapidCode does not take ownership of the callback, so it must stay referenced until the program stops (see GC.KeepAlive below)
SampleGcodeCallback callback = new();
// Since callback only logs, it will never affect following G-code and we can disable reloading after execution
robot.Gcode.CallbackRegister(callback, reloadAfterCallback: false);
// load and prepare G-Code for execution
robot.Gcode.Load(gcodeProgram);
Console.WriteLine($"Error loading G-Code: {e.Message}");
Helpers.CheckErrors(robot.Gcode); // get additional G-Code error details
throw;
// print motion details
Console.WriteLine($"G-Code Line Count: {robot.Gcode.LineCountGet()}");
Console.WriteLine($"G-Code Error Log Count: {robot.Gcode.ErrorLogCountGet()}");
Console.WriteLine($"G-code estimated run time: {robot.Gcode.DurationGet()} seconds");
// start motion
robot.Gcode.Run();
// monitor execution
Int64 activeLineNumber = 0;
do
Thread.Sleep(20);
if (activeLineNumber != robot.Gcode.ExecutingLineNumberGet()) // only write if on new line
activeLineNumber = robot.Gcode.ExecutingLineNumberGet();
Console.WriteLine($"G-Code Line Number: {activeLineNumber}");
} while (robot.Gcode.IsRunning());
if (robot.Gcode.IsRunning())
robot.Gcode.Cancel(); // an exception left the program running
robot.Gcode.CallbackRegister(null, reloadAfterCallback: false); // unregister before the callback can be collected
// RapidCode does not own the callback: keep it alive while it is registered, or the garbage collector may collect it mid-program
GC.KeepAlive(callback);
Helpers.CheckErrors(robot.Gcode); // check for motion errors
jointsMultiAxis.AmpEnableSet(false);
jointsMultiAxis.AxisRemoveAll();
Console.WriteLine("✅ G-Code motion completed successfully");
public class SampleGcodeCallback : GcodeCallback
public override void Execute(GcodeCallbackData data)
Console.WriteLine("G-Code Callback executed: " + data.LineNumber + " " + data.LineText);
// if you want to notify the Gcode object that there's an error processing, set its error details:
// data.UserError.number = RSIErrorMessage.RSI_ERROR_MESSAGE_DYNAMIC;
// data.UserError.text = "This is an error from the callback.";
const int AXIS_3_INDEX
Default: 3.
Definition _constants.cs:23
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
Definition rsi.h:860
void AxisRemoveAll()
Definition rsi.h:12226
Run, PlannedPositionsGet
