The RapidCode base class. All non-error objects are derived from this class. More...
Functions
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t NumberGet ()
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Description
The RapidCodeObject class contains the Error Log and access functions. Storing up to 100 RsiError items, RapidCodeObject makes them available to you with the ErrorLogGet function. ErrorLogCountGet returns the number of unread errors and should be greater than 0 when using ErrorLogGet. Each ErrorLogGet call returns a single unread RsiError per call. RapidCodeObject also provides the RSI version information.
StreamingMotionBufferManagement.cpp, _helpers.cs, and helpers.h.
Definition at line 180 of file rsi.h.
