10.6.0
AKDASCIICommand()
char * AKDASCIICommand
const char *const
command
command
the command to send (for example, try "DRV.INFO")
the text response from the AKD drive
Axis: Homing
// 1. READY DRIVE
axis.
OperationModeSet
RSIOperationMode
.RSIOperationModeHOMING_MODE);
// Mode of Operation set to Homing Mode.
axis.
NetworkNode
AKDASCIICommand
"DRV.OPMODE 2"
// Sets the drive operation mode (0 - current | 1 = velocity | 2 = position).
axis.
NetworkNode
AKDASCIICommand
"HOME.AUTOMOVE 0"
// 0 = Disabled | 1 = Homing starts when drive is enabled.
// Make sure you know your motor's position, velocity, and acceleration units before you send any values.
// 2. SET YOUR LIMIT SWITCHES
axis.
NetworkNode
AKDASCIICommand
"DIN5.MODE 18"
// Sets the digital input modes. - DI5 is now our Positive Limit Switch.
axis.
NetworkNode
AKDASCIICommand
"DIN5.INV 1"
// Sets the indicated polarity of a digital input mode. - DI5 is now active when Low.
axis.
NetworkNode
AKDASCIICommand
"DIN6.MODE 19"
// Sets the digital input modes. - DI6 is now our Negative Limit Switch.
axis.
NetworkNode
AKDASCIICommand
"DIN6.INV 1"
// Sets the indicated polarity of a digital input mode. - DI6 is now active when Low.
// 3. CONFIGURE DRIVE HOMING PARAMETERS
axis.
NetworkNode
AKDASCIICommand
"HOME.MODE 1"
// Selects the homing method. MODE1 = Find limit input
axis.
NetworkNode
AKDASCIICommand
"HOME.V 20"
axis.
NetworkNode
AKDASCIICommand
"HOME.ACC 200"
axis.
NetworkNode
AKDASCIICommand
"HOME.DEC 200"
axis.
NetworkNode
AKDASCIICommand
"HOME.DIR 0"
// Sets homing direction (0 = negative | 1 = positive)
axis.
NetworkNode
AKDASCIICommand
"HOME.P 0"
axis.
NetworkNode
AKDASCIICommand
"HOME.DIST 0"
axis.
NetworkNode
AKDASCIICommand
"HOME.MAXDIST 0"
axis.
NetworkNode
AKDASCIICommand
"HOME.IPEAK"
// 4. READY AXIS
axis.
ErrorLimitActionSet
.RSIActionNONE);
//Set the action to none so we don't get a position error while the drive is in control.
axis.
Abort
// Disable axis.
axis.
ClearFaults
// Clear any faults.
axis.
AmpEnableSet
true
// Enable the axis.
System.Threading.Thread.Sleep(100);
// Allow time for amp enable
// 5. START HOMING
axis.
NetworkNode
AKDASCIICommand
"HOME.MOVE"
// Starts a homing procedure; active in opmode 2 (position) only.
Console.WriteLine(
"HOME.MOVE"
// 6. CHECK IF HOMING IS DONE
UInt16 statusWordValue;
int
isHomedvalue = 0;
int
axisIndex = axis.
NumberGet
while
(isHomedvalue != 1)
// When isHomedValue = 1, homing has finished.
statusWordValue = axis.
NetworkNode
StatusWordGet
(axisIndex);
isHomedvalue = statusWordValue >> 12;
// Get the 12th bit only. This bit tells us homing is done when it goes HIGH.
Console.WriteLine(
"Axis homed."
// 7. CLEAN UP
axis.
OriginPositionSet
(0.0);
//Set the origin to 0, otherwise repeated use will not result in Rapidcode reporting 0 at the found home position.
axis.
Abort
// Disable the axis.
axis.
OperationModeSet
RSIOperationMode
.RSIOperationModeINTERPOLATED_POSITION_MODE);
// Mode of Operation Restore
axis.
ErrorLimitActionSet
.RSIActionABORT);
// Restore the position error action to whatever you want it to be.
Homing.cs
NetworkNode
1.10.0
