◆ MoveVelocitySCurve()
void MoveVelocitySCurve ( const double *const velocity,
const double *const accel,
const double *const jerkPct )
MoveVelocitySCurve commands the MultiAxis to a specified target velocity for each Axis.
*velocityArray of target velocities (UserUnits/second).
*accelArray of average accelerations (UserUnits/second/second). (peak up to 2× accel when jerkPercent = 100, see below)
*jerkPct0.0 to 100.0 - The percentage of acceleration time which is smoothed.
Motion: Multi-Axis
/* This sample demonstrates updating a multi-axis velocity synchronously and on the fly.
It can update velocities at a rate of ~2ms.
Before running this sample app:
1. Make sure to configure your Multi-Axis on RapidSetup.
2. Make sure to adjust your Limits and Action for all axes.
using System.Threading;
Console.WriteLine("📜 MultiAxis Motion: Velocity");
const int CYCLES = 3; // how many times to update the velocity
// get axes
Helpers.CheckErrors(axis0);
Helpers.CheckErrors(axis1);
Axis axis2 = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(axis2);
// get multiaxis (motion supervisor number is equal to number of axes because indexing starts at 0)
Helpers.CheckErrors(multi);
// remove any existing axes
multi.AxisRemoveAll();
// add axes to multiaxis
multi.AxisAdd(axis0);
multi.AxisAdd(axis1);
multi.AxisAdd(axis2);
// prepare for motion
multi.Abort();
multi.ClearFaults();
// define motion parameters
double[] accelerations = [20, 20, 20];
double[] velocities = [0, 0, 0];
Random rnd = new Random(); // for generating random velocities
// update velocities on the fly
for (int i = 0; i < CYCLES; i++)
// generate random velocities for all axes
velocities[0] = rnd.Next(1, 16);
velocities[1] = rnd.Next(1, 16);
velocities[2] = rnd.Next(1, 16);
Console.WriteLine($"Cycle {i + 1}: Velocities = [{velocities[0]}, {velocities[1]}, {velocities[2]}]");
// move multiaxis (this will also update the move on the fly)
multi.MoveVelocity(velocities, accelerations);
// short delay before next iteration
Thread.Sleep(2000);
// clean up
Helpers.AbortMotionObject(multi); // stop motion on all axes
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
Definition rsi.h:5962
void AxisRemoveAll()
Velocity move.
void AxisAdd(Axis *axis)
Definition rsi.h:10883
MotionAttributeMaskGet
