◆ RecorderRecordDataRetrieveBulk()
int32_t RecorderRecordDataRetrieveBulk ( int32_t recorderNumber,
int32_t recordCount )
RecorderRecordDataRetrieveBulk retrieves a group of records from the Recorder, and stores it in the MotionController.
recorderNumberThe index of the recorder. 0 to 63 by default.
recordCountThe count of records to be read. 1 to 1024. Internally limited.
The number of records which were retrieved from the Recorder to Controller memory.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5556
Definition rsi.h:10971
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3697
Definition rsienums.h:404
Definition rsienums.h:433
