◆ RecorderDataAddressSet()
void RecorderDataAddressSet ( int32_t index,
uint64_t address )
RecorderDataAddressSet sets the addresses to be recorded.
indexThe index of the data to be recorded.
addressThe host memory address of the value to be recorded.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5789
Definition rsi.h:11456
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3845
Definition rsienums.h:434
RecorderDataCountSet, AddressGet
RecordPerformance.cpp, and Recorder.cs.
