◆ RecorderRecordMaxCountGet()
int32_t RecorderRecordMaxCountGet ( )
RecorderRecordMaxCountGet returns the maximum number of records the recorder can store.
(int32_t) The number of records the recorder can store.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5666
Definition rsi.h:11081
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3796
Definition rsienums.h:404
Definition rsienums.h:433
