◆ RecorderRecordDataValueGet() [2/2]
int32_t RecorderRecordDataValueGet ( int32_t recorderNumber,
int32_t recordIndex,
int32_t dataIndex )
RecorderRecordDataValueGet gets one data value from a retrieved record.
recorderNumberIndex of the recorder. 0 to 63 Valid
recordIndexIndex of the collected Record. 0 to 1023 Valid
dataIndexIndex of the recorded data within that record. 0 to Number of Items collected - 1 Valid.
the int32_t value from the indexed data.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5870
Definition rsi.h:11559
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3846
Definition rsienums.h:434
RecorderRecordDataRetrieveBulk
