◆ RecorderCircularBufferSet()
void RecorderCircularBufferSet ( bool enable)
RecorderCircularBufferSet configures recorder as circular buffer on or off.
enableTrue = recorder keeps recording (and overwriting) after buffer is full, False = stops recording when buffer is full.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5556
Definition rsi.h:10971
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3697
Definition rsienums.h:404
Definition rsienums.h:433
RecorderStop
RecordPerformance.cpp, and Recorder.cs.
