Learn how to set the velocity based on an analog input value.
- Warning
📜 Velocity Set by Analog Input Value
This Sample App was created using the EL3002 Analog Input module. Please note that some variable values might changed based on your analog input module.
The functionality used with many other Analog Input modules, not only Beckhoff's.
Learn more about the EL3XXX analog input modules from beckhoff. (https://www.beckhoff.com/english/ethercat/analog.htm)
40
41 double analogMaxValue = 65536;
42 double currentVelocity = 0;
43 double analogCurrentValue = 0;
44 double analogValuePrecentage = 0;
45 double velocityAbsoluteSum = 0;
46
47
48 const int AXIS_NUMBER = 0;
49 const int NODE_NUMBER = 0;
50 const int ANALOG_INPUT_0 = 0;
51 const int MIN_VEL = -10;
52 const int MAX_VEL = 10;
53 const int ACC = 100;
54 const int USER_UNITS = 1048576;
55
56
60
63
64 IO ioNode = controller.
IOGet(NODE_NUMBER);
66
67 try
68 {
69
70 Console.WriteLine("Velocity Move Initialized.");
71 Console.WriteLine("Max Speed = " + MAX_VEL);
72 Console.WriteLine("Min Speed = " + MIN_VEL);
73 Console.WriteLine("\nPress SPACEBAR to exit.");
74
75
84
85 do
86 {
87 while (!Console.KeyAvailable)
88 {
89 velocityAbsoluteSum = Math.Abs(MIN_VEL) + Math.Abs(MAX_VEL);
90 analogCurrentValue = (double)ioNode.
AnalogInGet(ANALOG_INPUT_0);
91 analogValuePrecentage = analogCurrentValue / analogMaxValue;
92
93
94
95
96
97
98
99
100 if (analogValuePrecentage * 100 > 99 || analogValuePrecentage * 100 < 1)
101 currentVelocity = 0;
102
103 else if (analogValuePrecentage * 100 < 50)
104 currentVelocity = velocityAbsoluteSum * analogValuePrecentage;
105
106 else
107 currentVelocity = -velocityAbsoluteSum + (velocityAbsoluteSum * analogValuePrecentage);
108
110
111 }
112 } while (Console.ReadKey(true).Key != ConsoleKey.Spacebar);
113
115 }
116 catch (Exception e)
117 {
118 Console.WriteLine(e.Message);
119 }
Learn more in the concept page.
