◆ MoveSCurve() [2/3]
void MoveSCurve ( double position,
double vel,
double accel,
double decel,
double jerkPct )
MoveSCurve command a point-to-point motion, with a S-Curve velocity profile.
This type of motion has an "S" shape to the acceleration and deceleration phases. It uses the JerkPercent parameter to decide how much of the acceleration and deceleration phases is curved. A JerkPercent of zero produces a trapezoidal profile.
positionTarget Position in units.
velMaximum velocity, units/second.
accelMaximum accleration , units/second/second.
decelMaximum deceleration , units/second/second.
jerkPctJerk Percent, which defines the percentage of acceleration time which is smoothed, 0.0 to 100.0 .
Non-Blocking Execution Motion commands return instantly and do not pause code execution. Use MotionDoneWait() post-call to halt execution until motion completes.
SCurveMotion
axis.MoveSCurve(Constants.POSITION); // Command SCurve Motion. This overload willuse default velocity, acceleration, deceleration, jerk values for the axis. See axis config to learn how to set those values.
axis.MotionDoneWait(); // Wait for motion to finish
Motion Scope:
Trapezoidal Move profile shown below:
Point to Point, MoveSCurve, MoveRelative, MoveVelocity, MovePT, MovePVT
GearingCamming.cs, HelperFunctions.cs, Motion.cs, MotionModify.cs, PointToPoint.cpp, and UserLimit.cs.
