11.0.2
SettlingTimeSet()
void SettlingTimeSet
double
time
SettlingTimeSet sets the value which specifies the amount of time (seconds) that an
must be within the Fine Position Tolerance band before the motion is done.
time
In seconds.
AxisSettling
// get
double
posTolFine = axis.
PositionToleranceFineGet
double
posTolCoarse = axis.
PositionToleranceCoarseGet
double
velTol = axis.
VelocityToleranceGet
double
setTime = axis.
SettlingTimeGet
// set
axis.
PositionToleranceFineSet
(posTolFine);
axis.
PositionToleranceCoarseSet
(posTolCoarse);
axis.
VelocityToleranceSet
(velTol);
// set velocity tolerance.
axis.
SettlingTimeSet
(setTime);
SettlingTimeGet
axis-config-settling.cs
, and
axis-configuration.cpp
1.15.0
