void MoveRelative | ( | double | relativePosition, |
double | vel, | ||
double | accel, | ||
double | decel, | ||
double | jerkPct, | ||
double | finalVel ) |
MoveRelative with a final velocity.
relativePosition | A relative increment, positive or negative. |
vel | Maximum velocity, UserUnits/second. |
accel | Maximum acceleration , UserUnits/second/second. (peak up to 2× accel when jerkPercent = 100, see below) |
decel | Maximum deceleration , UserUnits/second/second. (peak up to 2× decel when jerkPercent = 100, see below) |
jerkPct | Jerk Percent, which defines the percentage of acceleration time which is smoothed, 0.0 to 100.0 . |
Part of the Motion method group. See the S-Curve Motion concept page for more information.
finalVel | Velocity the Axis will follow after completing the rest of the profile. |
