11.0.3
SettlingTimeGet()
double SettlingTimeGet
SettlingTimeGet gets the value which specifies the amount of time (seconds) that an
must be within the Fine Position Tolerance band before the motion is done.
(double) Time in seconds.
AxisSettling
// get
double
posTolFine = axis.
PositionToleranceFineGet
double
posTolCoarse = axis.
PositionToleranceCoarseGet
double
velTol = axis.
VelocityToleranceGet
double
setTime = axis.
SettlingTimeGet
// set
axis.
PositionToleranceFineSet
(posTolFine);
axis.
PositionToleranceCoarseSet
(posTolCoarse);
axis.
VelocityToleranceSet
(velTol);
// set velocity tolerance.
axis.
SettlingTimeSet
(setTime);
SettlingTimeSet
axis-config-settling.cs
, and
axis-configuration.cpp
1.15.0
