10.6.0
HardwareNegLimitActionSet()
void HardwareNegLimitActionSet
action
HardwareNegLimitActionSet sets the action that will occur when the Hardware Negative Limit Event triggers.
action
Action taken on Negative Limit trigger. A
value.
Note:
Available Actions are
Abort()
EStop()
Stop()
, None,
EStopAbort()
, and
EStopModify()
Axis: Configuration
const
bool
ACTIVE_HIGH =
true
// Constant for active high.
const
bool
ACTIVE_LOW =
false
// Constant for active low.
const
double
HW_POS_DURATION_TIME = 0.01;
const
double
HW_NEG_DURATION_TIME = 0.01;
axis.
HardwarePosLimitActionSet
.RSIActionE_STOP);
axis.
(ACTIVE_HIGH);
axis.
HardwarePosLimitDurationSet
(HW_POS_DURATION_TIME);
// GET
var hPosLimAct = axis.
HardwarePosLimitActionGet
var hPosLimTrigState = axis.
var hPosLimDur = axis.
HardwarePosLimitDurationGet
axis.
.RSIActionE_STOP);
axis.
(ACTIVE_LOW);
axis.
HardwareNegLimitDurationSet
(HW_NEG_DURATION_TIME);
// GET
var hNegLimAct = axis.
HardwareNegLimitActionGet
var hNegLimTrigState = axis.
var hNegLimDur = axis.
HardwareNegLimitDurationGet
Go to axis screen->Limits & Actions. In image below, HardwareNegLimitActionSet sets the action type shown in the Negative (-) Hardware box. It is currently set to E_STOP.
AxisConfig.cs
AxisConfiguration.cpp
HardwareLimits.cpp
Homing.cs
PhantomAxis.cpp
, and
SampleAppsHelper.h
1.10.0
