Template.cs
18using RSI.RapidCode.dotNET; // Import our RapidCode Library.
19using System;
20
21#if DOXYGEN // RSI internal documentation use only
22using RSI.RapidCode;
23#endif
24
26class Template
27 {
28 static void Main(string[] args)
29 {
30 // Constants
31 const int AXIS_NUMBER = 0; // Specify which axis/motor to control.
32 const int ENCODER_RESOLUTION_BITS = 20; // The number of bits defining the encoder resolution
33
34 // Specify your counts per unit/user units. (the motor used in this sample app has 1048576 encoder pulses per revolution)
35 double USER_UNITS = Math.Pow(2, ENCODER_RESOLUTION_BITS); //1048576 Setting the user units to this value will result in a commaneded position of 1 spinning the motor 1 full revolution
36
37 // Initialize RapidCode Objects
38 MotionController controller = MotionController.CreateFromSoftware(/*@"C:\RSI\X.X.X\"*/);// Insert the path location of the RMP.rta (usually the RapidSetup folder)
39 HelperFunctions.CheckErrors(controller); // [Helper Function] Check that the controller has been initialize correctly.
40 HelperFunctions.StartTheNetwork(controller); // [Helper Function] Initialize the network.
41 //controller.AxisCountSet(1); // Uncomment if using Phantom Axes.
42 Axis axis = controller.AxisGet(AXIS_NUMBER); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
43 HelperFunctions.CheckErrors(axis); // [Helper Function] Check that the axis has been initialize correctly.
44
45 try
46 {
47 axis.UserUnitsSet(USER_UNITS); // Specify the counts per Unit.
48 axis.ErrorLimitTriggerValueSet(1); // Specify the position error limit trigger. (Learn more about this on our support page)
49 axis.PositionSet(0); // Make sure motor starts at position 0 everytime.
50 axis.ErrorLimitTriggerValueSet(1); // Set the position error trigger value
51 axis.Abort(); // If there is any motion happening, abort it.
52 axis.ClearFaults(); // Clear faults.
53 axis.AmpEnableSet(true); // Enable the motor.
54
55 Console.WriteLine("\nHello RMP");
56
57 //-----INSERT YOUR SAMPLE CODE HERE-----
58
59
60 //-----INSERT YOUR SAMPLE CODE HERE-----
61 }
62 catch (Exception e)
63 {
64 Console.WriteLine(e.Message); // If there are any exceptions/issues this will be printed out.
65 }
66 controller.Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
67
68 Console.WriteLine("\nPress Any Key To Exit"); // Allow time to read Console.
69 Console.ReadKey();
70 }
71 }
Definition rsi.h:5870
Definition rsi.h:800
