Template.cs
using System;
#endif
class Template
static void Main(string[] args)
// Constants
const int ENCODER_RESOLUTION_BITS = 20; // The number of bits defining the encoder resolution
// Specify your counts per unit/user units. (the motor used in this sample app has 1048576 encoder pulses per revolution)
double USER_UNITS = Math.Pow(2, ENCODER_RESOLUTION_BITS); //1048576 Setting the user units to this value will result in a commaneded position of 1 spinning the motor 1 full revolution
MotionController controller = MotionController.CreateFromSoftware(/*@"C:\RSI\X.X.X\"*/);// Insert the path location of the RMP.rta (usually the RapidSetup folder)
HelperFunctions.CheckErrors(controller); // [Helper Function] Check that the controller has been initialize correctly.
HelperFunctions.StartTheNetwork(controller); // [Helper Function] Initialize the network.
//controller.AxisCountSet(1); // Uncomment if using Phantom Axes.
Axis axis = controller.AxisGet(AXIS_NUMBER); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
HelperFunctions.CheckErrors(axis); // [Helper Function] Check that the axis has been initialize correctly.
axis.UserUnitsSet(USER_UNITS); // Specify the counts per Unit.
axis.ErrorLimitTriggerValueSet(1); // Specify the position error limit trigger. (Learn more about this on our support page)
axis.PositionSet(0); // Make sure motor starts at position 0 everytime.
axis.ErrorLimitTriggerValueSet(1); // Set the position error trigger value
axis.Abort(); // If there is any motion happening, abort it.
axis.ClearFaults(); // Clear faults.
axis.AmpEnableSet(true); // Enable the motor.
Console.WriteLine("\nHello RMP");
//-----INSERT YOUR SAMPLE CODE HERE-----
Console.WriteLine(e.Message); // If there are any exceptions/issues this will be printed out.
controller.Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
Console.WriteLine("\nPress Any Key To Exit"); // Allow time to read Console.
Console.ReadKey();
Definition rsi.h:5556
Definition rsi.h:795
