using RSI.RapidCode.dotNET;
using NUnit.Framework;
using System;
#if DOXYGEN
#endif
    [Test]
    public void Recorder()
      const int VALUES_PER_RECORD     = 2;
      const int RECORD_PERIOD_SAMPLES = 1;
      const int RECORD_TIME           = 250;
      const int INPUT_INDEX           = 0;
      Axis axis = CreateAndReadyAxis(Constants.AXIS_NUMBER);
      Console.WriteLine("There are {0} Records available.", recordsAvailable);
          i = recordsAvailable;
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
