HardwareLimits.cpp
#include "SampleApps.h"
int HardwareLimits::Run()
/* CONSTANTS */
const double USER_UNITS = 1048576; // Specify your counts per unit / user units. (the motor used in this example has 1048576 encoder pulses per revolution)
// Hardware Limit configuration parameters
const bool ACTIVE_HIGH = true; // Constant for active high.
const bool ACTIVE_LOW = false; // Constant for active low.
const double HW_POS_DURATION_TIME = 0.01; // Positive limit duration. (in seconds)
const double HW_NEG_DURATION_TIME = 0.01; // Negative limit duration. (in seconds)
USE_HARDWARE = false;
const std::string rmpPath = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)
/* SAMPLE APP BODY */
MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
if (USE_HARDWARE)
printf("Hardware Limits Example\n");
// Change Hardware POSITIVE (+) Limit characteristicpp.
axis->HardwarePosLimitActionSet(RSIAction::RSIActionE_STOP); // Set the positive limit action to E_STOP.
printf("\nHardware Positive Limit Action set to %i", axis->HardwarePosLimitActionGet());
axis->HardwarePosLimitTriggerStateSet(ACTIVE_HIGH); // Set the positive limit trigger state to ACTIVE_HIGH.
printf("\nHardware Positive Limit TriggerState set to %i", axis->HardwarePosLimitTriggerStateGet());
axis->HardwarePosLimitDurationSet(HW_POS_DURATION_TIME); // Set the positive limit duration to 0.01 seconds.
printf("\nHardware Positive Limit Duration set to %f seconds", axis->HardwarePosLimitDurationGet());
// Change Hardware NEGATIVE (-) Limit charateristicpp.
axis->HardwareNegLimitActionSet(RSIAction::RSIActionE_STOP); // Set the negative limit action to E_STOP.
printf("\nHardware Negative Limit Action set to %i", axis->HardwareNegLimitActionGet());
axis->HardwareNegLimitTriggerStateSet(ACTIVE_LOW); // Set the negative limit trigger state to ACTIVE_LOW.
printf("\nHardware Negative Limit TriggerState set to %i", axis->HardwareNegLimitTriggerStateGet());
axis->HardwareNegLimitDurationSet(HW_NEG_DURATION_TIME); // Set the negative limit duration to 0.01 seconds.
printf("\nHardware Negative Limit Duration set to %f seconds", axis->HardwareNegLimitDurationGet());
printf("\nAll Hardware Limit characteristicpp set\n");
catch (RsiError const& err)
printf("\n%s\n", err.text);
return -1;
return 0;
sets the trigger state.
trigger state return.
Trigger state return.
Sets the trigger state.
Definition rsi.h:111
@ RSIActionE_STOP
Definition rsienums.h:1259
