Velocity Motion
Types of velocity motions.
🔹 What is Velocity Motion?
Velocity motion commanding an axis to reach a given velocity instead of a given position. Once the axis reachs the target velocity, it will continue moving at that velocity until it is stopped, aborted, or given another command.
📜 Sample Code
Basic Velocity Motion
  • C#
    axis.MoveVelocity(VELOCITY, ACCELERATION); // move at constant velocity
  • C++
    const int NUM_AXES = 1; // the number of axes to configure
    // motion Parameters
    const double POSITION_0 = 0; // specify the start position
    const double POSITION_1 = 0.5; // specify the position to move to
    const double VELOCITY = 1; // specify your velocity - units: UserUnits/Sec
    const double ACCELERATION = 10; // specify your acceleration - units: UserUnits/Sec^2
    const double DECELERATION = 10; // specify your deceleration - units: UserUnits/Sec^2
    const double JERK_PERCENT = 50; // specify your jerk percent (0.0 to 100.0)
    const double FINAL_VELOCITY = 0.5; // specify your final velocity - units: UserUnits/Sec
    std::cout << "Velocity Move:" << std::endl;
    std::cout << "Accelerating to velocity: " << VELOCITY << std::endl;
    axis->MoveVelocity(VELOCITY, ACCELERATION);
    HelperAtVelocityWait(controller, axis, TIMEOUT);
    std::cout << "Decelerating to velocity: " << 0 << std::endl;
    axis->MoveVelocity(0, DECELERATION);
Velocity Set by Analog Input Value
This Sample App was created using the EL3002 Analog Input module. Please note that some variable values might changed based on your analog input module.
The functionality used with many other Analog Input modules, not only Beckhoff's.
Learn more about the EL3XXX analog input modules from Beckhoff.
  • C#
    /* This sample demonstrates how to control axis velocity dynamically using an analog input value.
    The analog input value (0 to 65536 for a 16-bit input) is mapped to a velocity range.
    This was created using the EL3002 Analog Input module but works with many other modules.
    using System.Threading;
    Console.WriteLine("📜 Axis Motion: Velocity via Analog Input");
    const double ACCELERATION = 100;
    const double MAX_VEL = 10;
    const double MAX_ANALOG = 65536; // 16-bit analog input
    const int RUN_TIME_SECONDS = 20; // how long to run the velocity control loop
    // get phantom axis
    Axis axis = controller.AxisGet(Constants.AXIS_1_INDEX);
    // get node
    Helpers.CheckErrors(node);
    // configure axis
    // print sample info
    Console.WriteLine($"Max Speed = {MAX_VEL}");
    Console.WriteLine($"Running for {RUN_TIME_SECONDS} seconds...\n");
    // control velocity based on analog input
    var startTime = DateTime.Now;
    while ((DateTime.Now - startTime).TotalSeconds < RUN_TIME_SECONDS)
    // get analog input value and normalize to 0.0 - 1.0
    double analogValue = node.AnalogInGet(analogChannel: 0);
    double normalizedValue = analogValue / MAX_ANALOG;
    │ Analog Input Value Maps Linearly to Velocity │
    │ Analog: 0 ............................ 65,536 │
    │ Velocity: 0 ............................ MAX_VEL │
    // map analog input linearly to velocity (0 to MAX_VEL)
    double velocity = normalizedValue * MAX_VEL;
    axis.MoveVelocity(velocity, ACCELERATION);
    Thread.Sleep(1); // prevent cpu spin
    const int AXIS_1_INDEX
    Definition _constants.cs:21
    Definition rsi.h:6515
    Definition rsienums.h:617
🔹 Subsections
  • Final Velocity Motion : Perform an absolute or relative move with a specified final velocity.
  • Multi-Axis Velocity : Perform velocity moves on multiple axes that can be updated synchronously and on the fly.
