Perform velocity moves on multiple axes that can be updated synchronously and on the fly.
🔹 What is Multi-Axis Motion?
Multi-Axis Velocity Motion refers to a multi-axis velocity move that can be updated on the fly. This means that when a new velocity is commanded, all axes will update their velocities synchronously.
🔹 When to Use Multi-Axis Motion?
When it is necessary to update velocity, synchronously, and on the fly on multiple axes.
🔹 Multi-Axis Motion Test
In this picture, you can observe a Multi-Axis object updating its velocity 5 separate times every second. All 6 axes updated their velocity synchronously and on the fly. This means that every 1 second, the velocity of all 6 axes were updated and their update rate was tightly synchronized (happening at the same time).
.png)
In this picture, you can observe 6 axes Multi-Axis object being updated with different velocities every 100ms.
.png)
In this picture, you can observe how all 6 axes were updated every 100ms with random velocities, and every velocity update was happening at the same time (The vertical white lines display when a move is being updated).
.png)
Why did we Test?
It was important to see how fast we could update velocities on a Multi-Axis object and how synchronized these velocity moves would be.
Therefore, we ran a test that would update a Multi-Axis velocity 100,000 times. We found that every velocity update was happening at approximately 2ms.
Conclusion
A Multi-Axis object velocity can be updated every 2ms.
A Multi-Axis can change all its axes' velocities on the fly in a tightly synchronized manner
📜 Sample Code
- C#
using System.Threading;
Console.WriteLine("📜 MultiAxis Motion: Velocity");
const int CYCLES = 3;
double[] accelerations = [20, 20, 20];
double[] velocities = [0, 0, 0];
Random rnd = new Random();
for (int i = 0; i < CYCLES; i++)
velocities[0] = rnd.Next(1, 16);
velocities[1] = rnd.Next(1, 16);
velocities[2] = rnd.Next(1, 16);
Console.WriteLine($"Cycle {i + 1}: Velocities = [{velocities[0]}, {velocities[1]}, {velocities[2]}]");
Thread.Sleep(2000);
controller.Delete();
const int AXIS_1_INDEX
const int AXIS_2_INDEX
Default: 2.
void AxisRemoveAll()
Velocity move.
void AxisAdd(Axis *axis)
