Run a sample app in INtime in C++
Create C++ RapidCodeRT Hello World project that runs on the INtime kernel.
🔹 RMP INtime: Run a real-time program on INtime
The tutorial assumes you have INtime SDK and Visual Studio properly installed on a Windows PC
  1. Create your application using the INtime Application Wizard Image Image
  2. Add the C:\RSI\X.X.X|include\ folder to your Additional Include Directories. Image
  3. Add the RapidCodeRT.lib to your additional dependencies. Image
  4. Add the lib\rt subfolder to your Additional Library Directories Image
  5. Add your RMP license (rsi.lic) to project sources and set to "Copy file" so it's copied to your output folder. Image
  6. Add C:\RSI\X.X.X\RapidCodeRT.rsl to project sources and set to "Copy file" so it's copied to your output folder. Image
  7. Configure the Pool Maximum in the INtime Properties in project.
    • Pool Maximum (bytes)
    • Initial thread stack size (bytes)
      See the Tenasys Documentationfor more information about RTOS memory management.
  8. Run a simple program.
This example program requires that you have the RMP running and have set the axis count greater than 1. This can be done via RapidSetup.exe or rsiconfig.exe
Example Code:
#include <stdio.h>
using namespace RSI::RapidCode;
static void CheckErrors(RapidCodeObject* rsiObject)
bool hasErrors = false;
RsiError* err;
err = rsiObject->ErrorLogGet();
printf("%s\n", err->text);
hasErrors = true;
if (hasErrors)
printf("Exiting due to RapidCodeRT creation errors.\n");
exit(1);
CheckErrors(controller);
Axis* axis = controller->AxisGet(0); // Initialize Axis class
CheckErrors(axis);
try {
axis->ClearFaults();
axis->AmpEnableSet(true);
axis->MoveRelative(1);
while (!axis->MotionDoneGet()) {
printf("%8.3lf\n", axis->CommandPositionGet());
controller->OS->Sleep(100);
printf("\n%s\n", e.what());
printf("Exiting successfully.\n");
controller->Delete();
controller = nullptr;
return 0;
double CommandPositionGet()
Definition rsi.h:5870
uint32_t SerialNumberGet(void)
Definition rsi.h:800
RapidCodeOS * OS
Definition rsi.h:3846
bool MotionDoneGet()
int32_t ErrorLogCountGet()
Definition rsi.h:184
Definition rsi.h:111
