IO: User Limits (Digital Input)
User Limit Digital Input Action sample application.
s sample code shows how to configure the XMP controller's User Limits to compare an input bit to a specific pattern. the pattern matches, then the specified output bit is activated and a User Event is generated to the host.
Precondition
#include "SampleApps.h"
int UserLimitDigialInputAction::Run()
/* CONSTANTS */
const double USER_UNITS = 1048576; // Specify your counts per unit / user units. (the motor used in this example has 1048576 encoder pulses per revolution)
const int IO_NODE_NUMBER = 0; // which SqNode to use for I/O?
const int USER_LIMIT = 0; // which user limit to use?
const int CONDITION = 0; // which condition to use (0 or 1)
const int INPUT_BIT_NUMBER = 0; // which input bit?
USE_HARDWARE = false;
/* SAMPLE APP BODY */
if (USE_HARDWARE)
std::cout << "This sample app cannot be run without hardware." << std::endl;
return 0;
// RapidCode interface classes
IO* io;
IOPoint* digitalInput;
// Create a new User Limit
controller->UserLimitCountSet(1);
// initialize the I/O class
io = controller->IOGet(IO_NODE_NUMBER);
digitalInput = IOPoint::CreateDigitalInput(io, INPUT_BIT_NUMBER);
auto addr = digitalInput->AddressGet();
auto mask1 = digitalInput->MaskGet();
auto mask2 = digitalInput->MaskGet();
// configure user limit to evaluate input bit
controller->UserLimitConditionSet(USER_LIMIT,
CONDITION,
digitalInput->AddressGet(),
digitalInput->MaskGet(),
digitalInput->MaskGet());
// enable the user limit, generate ESTOP_ABORT action when input is turned on
controller->UserLimitConfigSet(USER_LIMIT, RSIUserLimitTriggerType::RSIUserLimitTriggerTypeSINGLE_CONDITION, RSIAction::RSIActionE_STOP_ABORT, AXIS_NUMBER, 0.0);
printf("Waiting for the input bit to go high...\n");
printf("\nPress Any Key To Exit.\n");
// wait for user limit to trigger
while (controller->OS->KeyGet((int32_t)RSIWait::RSIWaitPOLL) < 0)
printf("User Limit state is %d\r", controller->UserLimitStateGet(USER_LIMIT));
controller->OS->Sleep(1);
// disable User Limit
controller->UserLimitDisable(USER_LIMIT);
catch (RsiError const& rsiError)
printf("Text: %s\n", rsiError.text);
return -1;
return 0;
Definition rsi.h:12131
Definition rsi.h:11639
Definition rsi.h:111
@ RSIActionE_STOP_ABORT
E-Stop then Abort.
Definition rsienums.h:1166
@ RSIWaitPOLL
Definition rsienums.h:1077
@ RSIUserLimitTriggerTypeSINGLE_CONDITION
Only one condition is evaluated.
Definition rsienums.h:680
