Controller Interrupt
Controller Interrupts sample application.
Precondition
📜 Controller Interrupt
void controllerInterruptsMain()
const int TIMEOUT = (5000); //ms
RSIEventType interruptType;
// Initialize Controller, enable interrupts
MotionController *controller = MotionController::CreateFromSoftware();
controller->InterruptEnableSet(true);
SampleAppsHelper::StartTheNetwork(controller); // [Helper Function] Initialize the network.
while (controller->OS->KeyGet((int32_t)RSIWait::RSIWaitPOLL) < 0)
// add code here to generate interrupts (move axes, etc.)
// wait for an interrupt
interruptType = controller->InterruptWait(TIMEOUT);
if (interruptType != RSIEventType::RSIEventTypeTIMEOUT)
printf("IRQ %ld\n", interruptType);
printf("%s\n", controller->InterruptNameGet());
printf("InterruptSourceNumber = %ld\n", controller->InterruptSourceNumberGet());
printf("InterruptSampleTimer = %ld\n", controller->InterruptSampleTimeGet());
printf("\n");
printf("Timeout waiting for interrupts...\n");
catch (RsiError const& err)
printf("\n%s\n", err.text);
system("pause"); // Allow time to read Console.
Definition rsi.h:795
RapidCodeOS * OS
Definition rsi.h:3697
int32_t InterruptSampleTimeGet()
const char *const InterruptNameGet()
Definition rsi.h:106
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:920
