AxisStatus.cs
Attention
See the following Concept pages for a detailed explanation of this sample: Status & Faults.
using NUnit.Framework;
using System;
[TestFixture]
[Category("Software")]
class AxisStatusSample : SampleAppTestBase
public void AxisStatus()
//@[AxisStatus]
// CHECK AXIS STATE
RSIState state = axis.StateGet(); // StateGet will return RSIState enum name of the current state of the Axis or MultiAxis. (Ex: RSIStateERROR)
Console.WriteLine("Your Axis is in state: " + state);
switch (state)
case RSIState.RSIStateIDLE:
case RSIState.RSIStateMOVING:
case RSIState.RSIStateERROR:
case RSIState.RSIStateSTOPPING_ERROR:
case RSIState.RSIStateSTOPPED:
case RSIState.RSIStateSTOPPING:
RSISource source = axis.SourceGet(); // SourceGet will return the RSISource enum name of the first status bit that is active. (Ex: RSISourceAMP_FAULT)
Console.WriteLine("The source of the axis error is: " + axis.SourceNameGet(source)); // SourceNameGet will return the first status bit which is set on an Axis or MultiAxis.
default:
Console.WriteLine("");
// or USE STATUS BIT GET
bool isAmpFault_Active = axis.StatusBitGet(RSIEventType.RSIEventTypeAMP_FAULT); // StatusBitGet returns the state of a status bit, true or false.
bool isPositionErrorLimitActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_ERROR);
bool isHWNegativeLimitActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_HW_NEG);
bool isHWPostiveLimitActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_HW_POS); // This can be done for all RSIEventTypes
//@[AxisStatus]
const char *const SourceNameGet(RSISource source)
RSIState StateGet()
RSISource SourceGet()
