◆ RecorderBufferHighCountSet()
void RecorderBufferHighCountSet ( int32_t bufferHighCount)
RecorderBufferHighCountSet sets the high count for the recording buffer. When the high count is reached, the motion controller will generate a RECORDER_HIGH interrupt.
bufferHighCountnumber of records stored before RECORDER_HIGH interrupt (1 to 32767)
Monitoring: Recorder
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:6515
Definition rsi.h:12240
RSIDataType
Definition rsienums.h:730
Definition rsienums.h:447
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
RecorderStart, InterruptEnableSet
