◆ RecorderStop()
void RecorderStop ( )
RecorderStop stops recording data.
Monitoring: Recorder
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:5963
Definition rsi.h:11639
RSIDataType
Definition rsienums.h:703
Definition rsienums.h:439
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
Recording will also stop if the buffer is full (and not set as circular).
RecorderStart
