◆ RecorderRecordDataValueGet() [1/2]
int32_t RecorderRecordDataValueGet ( int32_t index)
RecorderRecordDataValueGet gets one value from a retrieved record.
indexindex of the recorded value, within the record
the value from the index of the record
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5556
Definition rsi.h:10971
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3697
Definition rsienums.h:404
Definition rsienums.h:433
RecordPerformance.cpp, and Recorder.cs.
