◆ RecorderConfigureToTriggerOnMotion() [3/5]
void RecorderConfigureToTriggerOnMotion ( int32_t recorderNumber,
int32_t motionNumber,
bool triggerOnMotion )
recorderNumberThe number of the recorder to configure.
motionNumberThe motion number to use. Axis::NumberGet() or MultiAxis::NumberGet().
triggerOnMotionA boolean value to set the trigger state. TRUE = trigger on Motion.
RecorderConfigureToTriggerOnMotion sets the recorder to trigger on motion. The recording will start when motion begins, and it will automatically stop when the Motion Done condition is true.
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:5966
Definition rsi.h:11642
RSIDataType
Definition rsienums.h:664
Definition rsienums.h:439
Definition rsi.h:468
double Double
Definition rsi.h:477
int32_t Int32
32-bit signed integer.
Definition rsi.h:474
RecorderDataCountSet, RecorderTriggerOnMotionGet This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
