◆ RecorderRecordCountGet()
int32_t RecorderRecordCountGet ( )
RecorderRecordCountGet returns the number of records that are stored and ready for reading.
(int32_t) The number of records that have been recorded (not read).
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5870
Definition rsi.h:11559
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3846
Definition rsienums.h:434
RecorderRecordDataGet
RecordPerformance.cpp, and Recorder.cs.
