PrintNetworkTopology.cpp
10#include <iomanip>
11#include <iostream>
12#include <map>
13#include <sstream>
14#include <vector>
15
16#include "SampleAppsHelper.h" // Import our helper functions.
17#include "rsi.h" // Import our RapidCode Library.
18
19using namespace RSI::RapidCode; // Import the RapidCode namespace
20
21// Map of the RSINetworkType enum to string
22static const std::map<RSINetworkType, std::string> RSINetworkTypeMap = {
23 {RSINetworkType::RSINetworkTypeSTRING, "RSINetworkTypeSTRING"},
24 {RSINetworkType::RSINetworkTypeDUAL_STRING, "RSINetworkTypeDUAL_STRING"},
25 {RSINetworkType::RSINetworkTypeRING, "RSINetworkTypeRING"}
26};
27
28// Map of the RSINetworkState enum to string
29static const std::map<RSINetworkState, std::string> RSINetworkStateMap = {
30 {RSINetworkState::RSINetworkStateUNINITIALIZED, "RSINetworkStateUNINITIALIZED"},
31 {RSINetworkState::RSINetworkStateDISCOVERING, "RSINetworkStateDISCOVERING"},
32 {RSINetworkState::RSINetworkStateDISCOVERED, "RSINetworkStateDISCOVERED"},
33 {RSINetworkState::RSINetworkStatePREOPERATIONAL, "RSINetworkStatePREOPERATIONAL"},
34 {RSINetworkState::RSINetworkStateOPERATIONAL, "RSINetworkStateOPERATIONAL"},
35 {RSINetworkState::RSINetworkStateERROR, "RSINetworkStateERROR"},
36 {RSINetworkState::RSINetworkStateSHUTDOWN, "RSINetworkStateSHUTDOWN"},
37 {RSINetworkState::RSINetworkStateSTARTING, "RSINetworkStateSTARTING"}
38};
39
40// Constants for reading the device type from the Mdp
41struct MdpConstants
42{
43 static constexpr int DEVICE_TYPE_INDEX = 0x1000;
44 static constexpr int DEVICE_TYPE_SUB_INDEX = 0;
45 static constexpr int DEVICE_TYPE_BYTE_SIZE = 4;
46};
47
48// Helper function to get the list of network nodes from the controller
49static std::vector<RapidCodeNetworkNode *> GetNodeList(MotionController *controller)
50{
51 std::vector<RapidCodeNetworkNode *> nodes;
52 for (int i = 0; i < controller->NetworkNodeCountGet(); ++i)
53 {
54 RapidCodeNetworkNode *node = controller->NetworkNodeGet(i);
55
56 if (node == nullptr)
57 {
58 throw std::runtime_error("Error creating the network node, it is null.");
59 }
60
61 if (!node->Exists())
62 {
63 throw std::runtime_error("The network node should exist after we get it.");
64 }
65
66 nodes.push_back(node);
67 }
68 return nodes;
69}
70
71// Helper function to get the device type of a node from the Mdp
72static std::string GetDeviceType(RapidCodeNetworkNode *node)
73{
74 std::string deviceType = "";
75 try
76 {
77 uint32_t deviceTypeValue =
78 node->ServiceChannelRead(MdpConstants::DEVICE_TYPE_INDEX, MdpConstants::DEVICE_TYPE_SUB_INDEX, MdpConstants::DEVICE_TYPE_BYTE_SIZE);
79
80 std::ostringstream deviceTypeStream;
81 deviceTypeStream << "0x" << std::uppercase << std::setfill('0') << std::setw(8) << std::hex << deviceTypeValue;
82
83 deviceType = deviceTypeStream.str();
84 }
85 catch (std::exception err)
86 {
87 deviceType = "Exception trying to read device type";
88 }
89 return deviceType;
90}
91
92// Helper function to read the information of a node into a string
93static std::string ReadNodeInfo(RapidCodeNetworkNode *node)
94{
95 std::ostringstream nodeInfo;
96
97 nodeInfo << "\n"; // for spacing
98 nodeInfo << "Node[" << node->NumberGet() << "] - " << node->NameGet() << " ______________________________________________\n";
99
100 nodeInfo << " Vendor: " << node->VendorNameGet();
101 nodeInfo << " Product: " << node->ProductNameGet() << "\n";
102
103 nodeInfo << " VendorID: 0x" << std::hex << std::setw(8) << std::setfill('0') << node->VendorIdGet();
104 nodeInfo << " ProductCode: 0x" << std::setw(8) << node->ProductCodeGet() << "\n";
105
106 nodeInfo << " HardwareRev: 0x" << std::setw(8) << node->RevisionGet();
107 nodeInfo << " SerialNumber: " << node->SerialNumberGet() << "\n";
108
109 nodeInfo << " StationAlias: 0x" << std::setw(8) << node->StationAliasGet();
110 nodeInfo << " AxisCount: " << std::dec << node->AxisCountGet() << "\n";
111
112 nodeInfo << " DeviceType: " << GetDeviceType(node);
113 nodeInfo << " (For Mdp by reading SDO 0x" << std::hex << std::setw(4) << MdpConstants::DEVICE_TYPE_INDEX << ")\n";
114
115 nodeInfo << " SegmentCount: " << node->SegmentCountGet() << "\n";
116
117 nodeInfo << " DI: " << node->DigitalInCountGet();
118 nodeInfo << " DO: " << node->DigitalOutCountGet();
119 nodeInfo << " AI: " << node->AnalogInCountGet();
120 nodeInfo << " AO: " << node->AnalogOutCountGet() << "\n";
121
122 return nodeInfo.str();
123}
124
125int main()
126{
127 const std::string SAMPLE_APP_NAME = "Utilities: Print Network Topology";
128
129 // Print a start message to indicate that the sample app has started
130 SampleAppsHelper::PrintHeader(SAMPLE_APP_NAME);
131
132 /* RAPIDCODE INITIALIZATION */
133
134 // Create the controller
136 MotionController *controller = MotionController::Create(&params);
137
138 int exitCode = -1; // Set the exit code to an error value.
139 try // Ensure that the controller is deleted if an error occurs.
140 {
142
143 /* SAMPLE APP BODY */
144
145 // Get the nodes
146 std::vector<RapidCodeNetworkNode *> nodes = GetNodeList(controller);
147
148 // Print the network topology
149 std::ostringstream topologyInfo;
150
151 // Add the overview information
152 topologyInfo << "EtherCAT: " << std::to_string(nodes.size());
153 topologyInfo << " Nodes, " << RSINetworkTypeMap.at(controller->NetworkTypeGet());
154 topologyInfo << " " << RSINetworkStateMap.at(controller->NetworkStateGet()) << "\n";
155
156 // Add information for each node
157 for (RapidCodeNetworkNode *node : nodes)
158 {
159 topologyInfo << ReadNodeInfo(node);
160 }
161
162 // Add network input information
163 topologyInfo << "\nNetworkInputs count: " << controller->NetworkInputCountGet() << " _________________________________\n";
164 for (int i = 0; i < controller->NetworkInputCountGet(); ++i)
165 {
166 topologyInfo << " [" << i << "] - " << std::setw(70) << controller->NetworkInputNameGet(i);
167 topologyInfo << " Bits: " << controller->NetworkInputBitSizeGet(i) << "\n";
168 }
169
170 // Add network output information
171 topologyInfo << "NetworkOutputs count: " << controller->NetworkOutputCountGet() << " _________________________________\n";
172 for (int i = 0; i < controller->NetworkOutputCountGet(); ++i)
173 {
174 topologyInfo << " [" << i << "] - " << std::setw(70) << controller->NetworkOutputNameGet(i);
175 topologyInfo << " Bits: " << controller->NetworkOutputBitSizeGet(i) << "\n";
176 }
177
178 // Print the accumulated string
179 std::cout << topologyInfo.str() << std::endl;
180
181 exitCode = 0;
182 }
183 catch (const std::exception &ex)
184 {
185 std::cerr << ex.what() << std::endl;
186 exitCode = -1;
187 }
188 // Delete the controller as the program exits to ensure memory is deallocated in the correct order
189 controller->Delete();
190
191 // Print a message to indicate the sample app has finished and if it was successful or not
192 SampleAppsHelper::PrintFooter(SAMPLE_APP_NAME, exitCode);
193
194 return exitCode;
195}
NetworkNode * NetworkNodeGet(int32_t nodeNumber)
NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializ...
Definition rsi.h:794
Get the name of a PDO output.
RSINetworkType NetworkTypeGet()
Returns network type. (Currently only STRING type is supported.)
Definition rsi.h:855
