MotionStreaming.cs
Attention
See the following Concept pages for a detailed explanation of this sample: PT Streaming Motion, PVT Streaming Motion, PVAJT Streaming Motion, Streaming Motion Sync Outputs.
using NUnit.Framework;
using System;
using System.Linq;
#endif
[TestFixture]
[Category("Software")]
public class motionStreaming : SampleAppTestBase
[Test]
public void PTmotion()
int points = 3; // Specify the total number of streamed points.
int emptyCount = 2; // E-stop generated if there are this number or fewer frames loaded. (Typically for PT motion there are two frames per PT point)
double[] positions = { 1.0, 0.5, 0.75 }; // Specify the positions that you want to reach. (it can be n number)
double[] times = { 0.2, 0.3, 0.1 }; // Specify the times in which you want to reach each position. (velocity and acceleration is calculated by the RMP)
axis.MovePT(RSIMotionType.RSIMotionTypePT, // Specify the type of PT Motion that you want to perform. (RSIMotionType.RSIMotionTypePT, RSIMotionType.RSIMotionTypeBSPLINE, RSIMotionType.RSIMotionTypeBSPLINE2)
positions, // Specify the positions that you want to reach. (it can be n number)
times, // Specify the times in which you want to reach each position. (velocity and acceleration is calculated by the RMP)
points, // Specify the total number of streamed points.
emptyCount, // E-stop generated if there are this number or fewer frames loaded. (Typically for PT motion there are two frames per PT point)
false, // Specify whether points are kept, or are not kept.
true); // Specify if this is the last MovePT. (If True, this is the final point. If False, more points expected.)
axis.MotionDoneWait(); // Wait for motion to be completed.
Assert.That(axis.CommandPositionGet(), Is.EqualTo(positions.Last()), "The command position should be equal to last position in the array");
public void PVTmotion()
int points = 3; // Specify the total number of streamed points. (Very Important!)
int emptyCount = 2; // E-stop generated if there are this number or fewer frames loaded. (Typically for PVT motion there are two frames per PT point)
double[] velocities = { 12.0, 10.0, 6.0 }; // Specify the velocities that you want to use to reach your position.
double[] times = { 0.1, 0.2, 0.1 }; // Specify the times in which you want to reach each position. (acceleration is calculated by the RMP)
axis.MovePVT(positions, // Specify the positions that you want to reach. (it can be n number)
velocities, // Specify the velocities that you want to reach. (it can be n number)
emptyCount, // E-stop generated if there are this number or fewer frames loaded. (Typically for PVT motion there are two frames per PT point)
public void PVAJTmotion()
int emptyCount = 2; // E-stop generated if there aren't at least this many points loaded.
double[] velocities = { 10.0, 20.0, 40.0 }; // Specify the velocities that you want to use to reach your position.
double[] accelerations = { 4, 4, 4 }; // Specify the accelerations that you want to use to reach your position.
double[] jerks = { 50, 50, 50 }; // Specify the jerks that you want to use in each move.
double[] times = { 0.4, 0.2, 0.1 }; // Specify the times in which you want to reach each position.
axis.MovePVAJT(positions, // Specify the positions that you want to reach. (it can be n number)
accelerations, // Specify the accelerations that you want to use during every move.
jerks, // Specify the jerks that you want to use during every move.
emptyCount, // E-stop generated if there are this number or fewer frames loaded. (Typically for PVAJT motion there are two frames per PVAJT point)
true); // Specify if this is the last MovePVAJT. (If True, this is the final point. If False, more points expected.)
public void PTmotionWhileStopping()
const int points = 3; // Specify how many points per streaming motion method call.
const int emptyCount = 2; // E-stop generated if there aren't at least this many points loaded.
double[] first = { 0.1, 0.2, 0.3 }; // specify the array with position(s) that will go in the first MovePT call.
double[] second = { 0.4, 0.5, 0.6 }; // specify the array with position(s) that will go in the second MovePT call
double[] third = { 0.7, 0.8, 0.9 }; // specify the array with position(s) that will go in the third MovePT call
double[] time1 = { 0.3, 0.3, 0.3 }; // specify the array with time(s) that will go in the first MovePT call.
double[] time2 = { 0.2, 0.2, 0.2 }; // specify the array with time(s) that will go in the second MovePT call.
double[] time3 = { 0.25, 0.25, 0.25 }; // specify the array with time(s) that will go in the third MovePT call.
axis.MovePT(RSIMotionType.RSIMotionTypePT, first, time1, points, emptyCount, false, false); // Start motion and stream a point.
axis.MovePT(RSIMotionType.RSIMotionTypePT, second, time2, points, emptyCount, false, false); // Append a point.
// After you Stop() a streaming motion, you can do 2 things.
// 1. You can either RESUME motion and continue to append.
// 2. Or you can DISCARD the points before the stop and start new motion.
axis.Stop(); // Calling Stop() after streaming motion will put you in an STOPPED state.
//axis.EStop(); // Calling EStop() after streaming motion will put you in an ERROR state.
// Therefore, you must ClearFaults() before taking any action.
//axis.Abort(); // Calling Abort() after streaming motion will put you in an ERROR state and trigger an AmpEnable(false).
// Therefore, you must call AmpEnable(true) before taking action.
axis.MotionDoneWait(); // Wait for axis to come to a stop.
axis.Resume(); // Resume() is the key here.
// If you include Resume() you will append all next streaming points to the old ones.
// If you do not include Resume() you will discard all previous points and start with new motion with the new points.
axis.MovePT(RSIMotionType.RSIMotionTypePT, third, time3, points, emptyCount, false, true); // Depending on whether you include Resume() or not this point will be appended or will be starting motion.
double CommandPositionGet()
int32_t MotionDoneWait()
void Resume()
Resume an axis.
RSIMotionType
Definition rsienums.h:1038
