Motion.cs
Attention
See the following Concept pages for a detailed explanation of this sample: Final Velocity Motion, Absolute Motion, Relative Motion, S-Curve Motion, Velocity Motion.
using NUnit.Framework;
[TestFixture]
[Category("Software")]
public class Motion : SampleAppTestBase
public void AbsoluteMotion()
axis.MoveTrapezoidal(Constants.POSITION, Constants.VELOCITY, Constants.ACCELERATION, Constants.DECELERATION);// Command simple trapezoidal motion.
axis.MotionDoneWait();// Wait for motion to be done
Assert.That(axis.CommandPositionGet(), Is.EqualTo(Constants.POSITION), "The command position should be equal to POSITION");
public void SCurveMotion()
axis.MoveSCurve(Constants.POSITION); // Command SCurve Motion. This overload willuse default velocity, acceleration, deceleration, jerk values for the axis. See axis config to learn how to set those values.
axis.MotionDoneWait(); // Wait for motion to finish
public void FinalVelocity()
int finalVelocity = 5;
axis.MoveSCurve(Constants.POSITION, // Command an SCurve move with a final velocity of FINAL_VELOCITY.
Constants.VELOCITY,
Constants.DECELERATION,
Constants.JERK_PERCENT,
finalVelocity); // Once the commanded position has been reached, the motor will begin spinning with a speed of FINAL_VELOCITY, and continue to spin at that velocity until stopped.
Assert.That(axis.CommandVelocityGet(), Is.EqualTo(finalVelocity), "The command velocity should be equal to FINAL_VELOCITY");
TearDown();
public void RelativeMotion()
axis.MoveRelative(Constants.POSITION, Constants.VELOCITY, Constants.ACCELERATION, Constants.DECELERATION, Constants.JERK_PERCENT); // Command a relative to the current position
axis.MotionDoneWait(); // Wait for motion to finish. (the motion should take 2.5 seconds)
var cmdPositionAfterMove = axis.CommandPositionGet(); // The command position should be equal to Constants.POSITION
// Move back to the start position by moving negative relative to current position
axis.MoveRelative(-1 * Constants.POSITION, Constants.VELOCITY, Constants.ACCELERATION, Constants.DECELERATION, Constants.JERK_PERCENT);
Assert.That(cmdPositionAfterMove, Is.EqualTo(Constants.POSITION), "The command position should be equal to POSITION");
[Test]
public void MoveVelocity()
// Command a velocity move
axis.MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
Assert.That(axis.CommandVelocityGet(), Is.EqualTo(Constants.VELOCITY), "The command velocity should be equal to FINAL_VELOCITY");
TearDown();
const double POSITION
@[BasicConstants]
double CommandPositionGet()
double CommandVelocityGet()
Get the current commanded velocity.
int32_t MotionDoneWait()
