AxisStatus.cs
29using RSI.RapidCode.dotNET; // Import our RapidCode Library.
30using NUnit.Framework;
31using System;
32
34[TestFixture]
35[Category("Software")]
36class AxisStatusSample : SampleAppTestBase
37 {
38 [Test, Timeout(Constants.MAX_TEST_TIME)]
39 public void AxisStatus()
40 {
41 //@[AxisStatus]
42
43
44 // CHECK AXIS STATE
45 RSIState state = axis.StateGet(); // StateGet will return RSIState enum name of the current state of the Axis or MultiAxis. (Ex: RSIStateERROR)
46 Console.WriteLine("Your Axis is in state: " + state);
47
48 switch (state)
49 {
50 case RSIState.RSIStateIDLE:
51 case RSIState.RSIStateMOVING:
52 break;
53 case RSIState.RSIStateERROR:
54 case RSIState.RSIStateSTOPPING_ERROR:
55 case RSIState.RSIStateSTOPPED:
56 case RSIState.RSIStateSTOPPING:
57 RSISource source = axis.SourceGet(); // SourceGet will return the RSISource enum name of the first status bit that is active. (Ex: RSISourceAMP_FAULT)
58 Console.WriteLine("Your Axis is in state: " + state);
59 Console.WriteLine("The source of the axis error is: " + axis.SourceNameGet(source)); // SourceNameGet will return the first status bit which is set on an Axis or MultiAxis.
60 break;
61 default:
62 Console.WriteLine("");
63 break;
64 }
65
66 // or USE STATUS BIT GET
67
68 bool isAmpFault_Active = axis.StatusBitGet(RSIEventType.RSIEventTypeAMP_FAULT); // StatusBitGet returns the state of a status bit, true or false.
69 bool isPositionErrorLimitActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_ERROR);
70 bool isHWNegativeLimitActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_HW_NEG);
71 bool isHWPostiveLimitActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_HW_POS); // This can be done for all RSIEventTypes
72
73 //@[AxisStatus]
74 }
75 }
const char *const SourceNameGet(RSISource source)
RSIState StateGet()
RSISource SourceGet()
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:966
RSISource
Definition rsienums.h:1014
