RapidCode NetworkNode
Table of Contents
The NetworkNode object represents an EtherCAT Node (SubDevice) (Drive, IO Block, etc) on the network. Accessible via MotionController and Axis objects.
The NetworkNode class provides an interface to all digital and analog I/O on the node, as well as the ability to read and write SDOs. Get or create a NetworkNode using NetworkNodeGet or the Axis property, NetworkNode.
Multiple Axis objects can reference the same network node as seen by the Copley Multi-Axis node.
📜 Sample Code
The following sample apps shows how to print your network topology, including information about each network node.
  • C++
    /* This sample app demonstrates how to print the network topology
    including nodes, states, and configuration details.
    #include <iomanip>
    #include <iostream>
    #include <map>
    #include <sstream>
    #include <vector>
    // map of the RSINetworkType enum to string
    static const std::map<RSINetworkType, std::string> RSINetworkTypeMap = {
    {RSINetworkType::RSINetworkTypeSTRING, "RSINetworkTypeSTRING"},
    {RSINetworkType::RSINetworkTypeDUAL_STRING, "RSINetworkTypeDUAL_STRING"},
    {RSINetworkType::RSINetworkTypeRING, "RSINetworkTypeRING"}
    // map of the RSINetworkState enum to string
    static const std::map<RSINetworkState, std::string> RSINetworkStateMap = {
    {RSINetworkState::RSINetworkStateUNINITIALIZED, "RSINetworkStateUNINITIALIZED"},
    {RSINetworkState::RSINetworkStateDISCOVERING, "RSINetworkStateDISCOVERING"},
    {RSINetworkState::RSINetworkStateDISCOVERED, "RSINetworkStateDISCOVERED"},
    {RSINetworkState::RSINetworkStatePREOPERATIONAL, "RSINetworkStatePREOPERATIONAL"},
    {RSINetworkState::RSINetworkStateOPERATIONAL, "RSINetworkStateOPERATIONAL"},
    {RSINetworkState::RSINetworkStateERROR, "RSINetworkStateERROR"},
    {RSINetworkState::RSINetworkStateSHUTDOWN, "RSINetworkStateSHUTDOWN"},
    {RSINetworkState::RSINetworkStateSTARTING, "RSINetworkStateSTARTING"}
    // constants for reading the device type from the Mdp
    struct MdpConstants
    static constexpr int DEVICE_TYPE_INDEX = 0x1000;
    static constexpr int DEVICE_TYPE_SUB_INDEX = 0;
    static constexpr int DEVICE_TYPE_BYTE_SIZE = 4;
    // helper function to get the list of network nodes from the controller
    static std::vector<RapidCodeNetworkNode *> GetNodeList(MotionController *controller)
    std::vector<RapidCodeNetworkNode *> nodes;
    for (int i = 0; i < controller->NetworkNodeCountGet(); ++i)
    RapidCodeNetworkNode *node = controller->NetworkNodeGet(i);
    if (node == nullptr)
    throw std::runtime_error("Error creating the network node, it is null.");
    if (!node->Exists())
    throw std::runtime_error("The network node should exist after we get it.");
    nodes.push_back(node);
    return nodes;
    // helper function to get the device type of a node from the Mdp
    static std::string GetDeviceType(RapidCodeNetworkNode *node)
    std::string deviceType = "";
    uint32_t deviceTypeValue =
    node->ServiceChannelRead(MdpConstants::DEVICE_TYPE_INDEX, MdpConstants::DEVICE_TYPE_SUB_INDEX, MdpConstants::DEVICE_TYPE_BYTE_SIZE);
    std::ostringstream deviceTypeStream;
    deviceTypeStream << "0x" << std::uppercase << std::setfill('0') << std::setw(8) << std::hex << deviceTypeValue;
    deviceType = deviceTypeStream.str();
    catch (std::exception err)
    deviceType = "Exception trying to read device type";
    return deviceType;
    // helper function to read the information of a node into a string
    static std::string ReadNodeInfo(RapidCodeNetworkNode *node)
    std::ostringstream nodeInfo;
    nodeInfo << "\n"; // for spacing
    nodeInfo << "Node[" << node->NumberGet() << "] - " << node->NameGet() << " ______________________________________________\n";
    nodeInfo << " Vendor: " << node->VendorNameGet();
    nodeInfo << " Product: " << node->ProductNameGet() << "\n";
    nodeInfo << " VendorID: 0x" << std::hex << std::setw(8) << std::setfill('0') << node->VendorIdGet();
    nodeInfo << " ProductCode: 0x" << std::setw(8) << node->ProductCodeGet() << "\n";
    nodeInfo << " HardwareRev: 0x" << std::setw(8) << node->RevisionGet();
    nodeInfo << " SerialNumber: " << node->SerialNumberGet() << "\n";
    nodeInfo << " StationAlias: 0x" << std::setw(8) << node->StationAliasGet();
    nodeInfo << " AxisCount: " << std::dec << node->AxisCountGet() << "\n";
    nodeInfo << " DeviceType: " << GetDeviceType(node);
    nodeInfo << " (For Mdp by reading SDO 0x" << std::hex << std::setw(4) << MdpConstants::DEVICE_TYPE_INDEX << ")\n";
    nodeInfo << " SegmentCount: " << node->SegmentCountGet() << "\n";
    nodeInfo << " DI: " << node->DigitalInCountGet();
    nodeInfo << " DO: " << node->DigitalOutCountGet();
    nodeInfo << " AI: " << node->AnalogInCountGet();
    nodeInfo << " AO: " << node->AnalogOutCountGet() << "\n";
    return nodeInfo.str();
    int main()
    const std::string SAMPLE_APP_NAME = "📜 Utilities: Print Network Topology";
    // Create the controller
    /* SAMPLE APP BODY */
    // Get the nodes
    std::vector<RapidCodeNetworkNode *> nodes = GetNodeList(controller);
    // Print the network topology
    std::ostringstream topologyInfo;
    // Add the overview information
    topologyInfo << "EtherCAT: " << std::to_string(nodes.size());
    topologyInfo << " Nodes, " << RSINetworkTypeMap.at(controller->NetworkTypeGet());
    topologyInfo << " " << RSINetworkStateMap.at(controller->NetworkStateGet()) << "\n";
    // Add information for each node
    for (RapidCodeNetworkNode *node : nodes)
    topologyInfo << ReadNodeInfo(node);
    // Add network input information
    topologyInfo << "\nNetworkInputs count: " << controller->NetworkInputCountGet() << " _________________________________\n";
    for (int i = 0; i < controller->NetworkInputCountGet(); ++i)
    topologyInfo << " [" << i << "] - " << std::setw(70) << controller->NetworkInputNameGet(i);
    topologyInfo << " Bits: " << controller->NetworkInputBitSizeGet(i) << "\n";
    // Add network output information
    topologyInfo << "NetworkOutputs count: " << controller->NetworkOutputCountGet() << " _________________________________\n";
    for (int i = 0; i < controller->NetworkOutputCountGet(); ++i)
    topologyInfo << " [" << i << "] - " << std::setw(70) << controller->NetworkOutputNameGet(i);
    topologyInfo << " Bits: " << controller->NetworkOutputBitSizeGet(i) << "\n";
    // Print the accumulated string
    std::cout << topologyInfo.str() << std::endl;
    exitCode = 0;
    exitCode = -1;
    controller->Delete();
    @ RSINetworkStatePREOPERATIONAL
    EtherCAT preoperational.
    Definition rsienums.h:625
    @ RSINetworkStateSHUTDOWN
    Definition rsienums.h:628
    @ RSINetworkStateDISCOVERED
    EtherCAT nodes discovered but not started.
    Definition rsienums.h:624
    @ RSINetworkStateDISCOVERING
    EtherCAT network is in the process of discovering nodes.
    Definition rsienums.h:623
    @ RSINetworkStateOPERATIONAL
    Definition rsienums.h:626
    @ RSINetworkStateSTARTING
    EtherCAT is starting.
    Definition rsienums.h:629
    EtherCAT not yet started.
    Definition rsienums.h:622
    @ RSINetworkTypeRING
    A Ring topology is a chain of linked Node(s) going from the Controllers Out port to the In port.
    Definition rsienums.h:754
    @ RSINetworkTypeSTRING
    A String topology is chain of linked Node(s) to the Controller from the In or Out port.
    Definition rsienums.h:752
    @ RSINetworkTypeDUAL_STRING
    A Dual String topology is two chained links of Node(s) to the Controller from the In and Out ports.
    Definition rsienums.h:753
    Definition config.h:81
    Definition helpers.h:87
    [NetworkShutdown]
    Definition helpers.h:205
    [PrintHeader]
    Definition helpers.h:221
    Definition rsi.h:872
