RapidCode NetworkNode
Table of Contents
The NetworkNode object represents an EtherCAT Node (SubDevice) (Drive, IO Block, etc) on the network. Accessible via MotionController and Axis objects.
Represents an EtherCAT node / SubDevice (Drive, I/O Block, etc) on the network. This class provides an interface to all digital and analog I/O on the node, as well as the ability to read and write SDOs. Get or create a NetworkNode using MotionController::NetworkNodeGet or the Axis property, NetworkNode.
Each RapidCodeNetworkNode represents a physical node (SubDevice) on the EtherCAT bus.
Multiple Axis objects can reference the same network node as seen by the Copley Multi-Axis node.
📜 Sample Code
The following sample apps shows how to print your network topology, including information about each network node.
  • C++
    #include <iomanip>
    #include <iostream>
    #include <map>
    #include <sstream>
    #include <vector>
    // Map of the RSINetworkType enum to string
    static const std::map<RSINetworkType, std::string> RSINetworkTypeMap = {
    {RSINetworkType::RSINetworkTypeSTRING, "RSINetworkTypeSTRING"},
    {RSINetworkType::RSINetworkTypeDUAL_STRING, "RSINetworkTypeDUAL_STRING"},
    {RSINetworkType::RSINetworkTypeRING, "RSINetworkTypeRING"}
    // Map of the RSINetworkState enum to string
    static const std::map<RSINetworkState, std::string> RSINetworkStateMap = {
    {RSINetworkState::RSINetworkStateUNINITIALIZED, "RSINetworkStateUNINITIALIZED"},
    {RSINetworkState::RSINetworkStateDISCOVERING, "RSINetworkStateDISCOVERING"},
    {RSINetworkState::RSINetworkStateDISCOVERED, "RSINetworkStateDISCOVERED"},
    {RSINetworkState::RSINetworkStatePREOPERATIONAL, "RSINetworkStatePREOPERATIONAL"},
    {RSINetworkState::RSINetworkStateOPERATIONAL, "RSINetworkStateOPERATIONAL"},
    {RSINetworkState::RSINetworkStateERROR, "RSINetworkStateERROR"},
    {RSINetworkState::RSINetworkStateSHUTDOWN, "RSINetworkStateSHUTDOWN"},
    {RSINetworkState::RSINetworkStateSTARTING, "RSINetworkStateSTARTING"}
    // Constants for reading the device type from the Mdp
    struct MdpConstants
    static constexpr int DEVICE_TYPE_INDEX = 0x1000;
    static constexpr int DEVICE_TYPE_SUB_INDEX = 0;
    static constexpr int DEVICE_TYPE_BYTE_SIZE = 4;
    // Helper function to get the list of network nodes from the controller
    static std::vector<RapidCodeNetworkNode *> GetNodeList(MotionController *controller)
    std::vector<RapidCodeNetworkNode *> nodes;
    for (int i = 0; i < controller->NetworkNodeCountGet(); ++i)
    RapidCodeNetworkNode *node = controller->NetworkNodeGet(i);
    if (node == nullptr)
    throw std::runtime_error("Error creating the network node, it is null.");
    if (!node->Exists())
    throw std::runtime_error("The network node should exist after we get it.");
    nodes.push_back(node);
    return nodes;
    // Helper function to get the device type of a node from the Mdp
    static std::string GetDeviceType(RapidCodeNetworkNode *node)
    std::string deviceType = "";
    uint32_t deviceTypeValue =
    node->ServiceChannelRead(MdpConstants::DEVICE_TYPE_INDEX, MdpConstants::DEVICE_TYPE_SUB_INDEX, MdpConstants::DEVICE_TYPE_BYTE_SIZE);
    std::ostringstream deviceTypeStream;
    deviceTypeStream << "0x" << std::uppercase << std::setfill('0') << std::setw(8) << std::hex << deviceTypeValue;
    deviceType = deviceTypeStream.str();
    catch (std::exception err)
    deviceType = "Exception trying to read device type";
    return deviceType;
    // Helper function to read the information of a node into a string
    static std::string ReadNodeInfo(RapidCodeNetworkNode *node)
    std::ostringstream nodeInfo;
    nodeInfo << "\n"; // for spacing
    nodeInfo << "Node[" << node->NumberGet() << "] - " << node->NameGet() << " ______________________________________________\n";
    nodeInfo << " Vendor: " << node->VendorNameGet();
    nodeInfo << " Product: " << node->ProductNameGet() << "\n";
    nodeInfo << " VendorID: 0x" << std::hex << std::setw(8) << std::setfill('0') << node->VendorIdGet();
    nodeInfo << " ProductCode: 0x" << std::setw(8) << node->ProductCodeGet() << "\n";
    nodeInfo << " HardwareRev: 0x" << std::setw(8) << node->RevisionGet();
    nodeInfo << " SerialNumber: " << node->SerialNumberGet() << "\n";
    nodeInfo << " StationAlias: 0x" << std::setw(8) << node->StationAliasGet();
    nodeInfo << " AxisCount: " << std::dec << node->AxisCountGet() << "\n";
    nodeInfo << " DeviceType: " << GetDeviceType(node);
    nodeInfo << " (For Mdp by reading SDO 0x" << std::hex << std::setw(4) << MdpConstants::DEVICE_TYPE_INDEX << ")\n";
    nodeInfo << " SegmentCount: " << node->SegmentCountGet() << "\n";
    nodeInfo << " DI: " << node->DigitalInCountGet();
    nodeInfo << " DO: " << node->DigitalOutCountGet();
    nodeInfo << " AI: " << node->AnalogInCountGet();
    nodeInfo << " AO: " << node->AnalogOutCountGet() << "\n";
    return nodeInfo.str();
    int main()
    const std::string SAMPLE_APP_NAME = "Utilities: Print Network Topology";
    // Create the controller
    MotionController *controller = MotionController::Create(&params);
    /* SAMPLE APP BODY */
    // Get the nodes
    std::vector<RapidCodeNetworkNode *> nodes = GetNodeList(controller);
    // Print the network topology
    std::ostringstream topologyInfo;
    // Add the overview information
    topologyInfo << "EtherCAT: " << std::to_string(nodes.size());
    topologyInfo << " Nodes, " << RSINetworkTypeMap.at(controller->NetworkTypeGet());
    topologyInfo << " " << RSINetworkStateMap.at(controller->NetworkStateGet()) << "\n";
    // Add information for each node
    for (RapidCodeNetworkNode *node : nodes)
    topologyInfo << ReadNodeInfo(node);
    // Add network input information
    topologyInfo << "\nNetworkInputs count: " << controller->NetworkInputCountGet() << " _________________________________\n";
    for (int i = 0; i < controller->NetworkInputCountGet(); ++i)
    topologyInfo << " [" << i << "] - " << std::setw(70) << controller->NetworkInputNameGet(i);
    topologyInfo << " Bits: " << controller->NetworkInputBitSizeGet(i) << "\n";
    // Add network output information
    topologyInfo << "NetworkOutputs count: " << controller->NetworkOutputCountGet() << " _________________________________\n";
    for (int i = 0; i < controller->NetworkOutputCountGet(); ++i)
    topologyInfo << " [" << i << "] - " << std::setw(70) << controller->NetworkOutputNameGet(i);
    topologyInfo << " Bits: " << controller->NetworkOutputBitSizeGet(i) << "\n";
    // Print the accumulated string
    std::cout << topologyInfo.str() << std::endl;
    exitCode = 0;
    exitCode = -1;
    controller->Delete();
    NetworkNode * NetworkNodeGet(int32_t nodeNumber)
    NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializ...
    Definition rsi.h:794
    Get the name of a PDO output.
    RSINetworkType NetworkTypeGet()
    Returns network type. (Currently only STRING type is supported.)
    Definition rsi.h:855
