Sample apps showing how the position of an axis can be driven by that of another axis.
- Warning
- Precondition
- This sample code presumes that the user has set the tuning paramters(PID, PIV, etc.) prior to running this program so that the motor can rotate in a stable manner.
📜 Camming
This sample application allows you to command a nonlinear coordinated motion betweentwo axes.
Moving Axis Axis: this axis/motor may or may not be controlled by the motion controller.
Driven Axis: the motion controller controls the position of this axis/motor as a function of the position of the Moving axis.
- Precondition
- User Units must be set to 1 ❗️
const double MAIN_VELOCITY = 50;
const double MAIN_ACCELERATION = 20;
double[] movingAxisDistances = { 5, 10, 8 };
double[] followerAxisPositions = { 10, 20, 10 };
movingAxisDistances,
followerAxisPositions,
movingAxisDistances.Length);
Learn more in the concept page.
📜 Gearing
Axis gearing on the XMP is based off of a Axis, RSIAxisMasterType, numerator, and denominator.
The Axis points to a Moving Axis axis to gear to.
The RSIAxisMasterType specifies what feedback source to gear to. The ratio between the lead and follower axes is set by a ratio of two longs – a numerator and a denominator.
int numerator = 2;
int denominator = 1;
numerator,
denominator);
